Build Hybrid Battery Maintenance Gear For Under $100
Discussion in 'Gen 2 Prius Main Forum' started by PriusCamper, Mar 25, 2021.
  1. ozmatt
    ozmatt Active Member
    604
    252
    australia
    i do not at the moment sorry but will get a picture next time i go to my workshop, its just a basic 12v constant voltage led driver around 1a from memory
    fach likes this.
  2. fach
    fach Junior Member
    28
    24
    Thank you so much! I finished the resistor/diode portion.
    alftoy and ozmatt like this.
  3. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
    fach likes this.
  4. fach
    fach Junior Member
    28
    24
    It happens that I have the parts from an old project. It is a simple PCB board to do it; I will add it to the parts list.
    #24 fach, Apr 4, 2021
    alftoy likes this.
  5. fach
    fach Junior Member
    28
    24
    @alftoy, how hot both transformers go? I am asking because right now, in the setup, they are resting in a plastic box (ammo box). If they go hot, I may need to raise it a little bit so that Air can Flow better Around the transformer. Also, the volt/amp can be feed with 12vdc? If it is like that, I can remove the voltage step down to feed that.
  6. PriusCamper
    PriusCamper Senior Member
    11,190
    4,559
    Pacific Northwest, USA
    Hope the ammo in the box doesn't get too hot or it might explode. :)
    fach likes this.
  7. alftoy
    1,132
    510
    My transformers are warm, I have lots of ventilation, but that ammo box might get warm, just monitor. Yes volt/amp works fine at 12vdc.
  8. fach
    fach Junior Member
    28
    24
    Thank you! I will raise the main transformer a little bit for better ventilation.
  9. PriusCamper
    11,190
    4,559
    Any thoughts on buying parts to build the fan controller for the hybrid battery's cooling fan yet?
  10. fach
    fach Junior Member
    28
    24
    @PriusCamper, I was thinking it is only two cables from the 12vdc to the fan. I have the plug (junker visit), and I ordered the sp20 connector with four pins (two for the battery, two for the fan). Is it somethig different?
  11. PriusCamper
    11,190
    4,559
    It's a variable speed cooling fan that depends on relays... I've had many debates with people who insist they tested it and in theory it works just by hooking up a 12v to it... But in practice it doesn't work. I think @alftoy pulled up the schematics to build the fan controller in here or somewhere else. Hopefully he sees this and reposts it.
  12. fach
    fach Junior Member
    28
    24
    @PriusCamper, I can do it as well. I hooked a 12vdc battery directly to the fan, and it works fine in full blast. I am interested to see how the relays are controlled.
    Solman636 likes this.
  13. PriusCamper
    11,190
    4,559
    Every time somebody told me they did what you did, they later come back and say it doesn't work anymore. Not sure why or if that's means they broke it or not. I'd like to learn more from some one who knows?
  14. alftoy
    1,132
    510
    Shouldn't be too hard to run the fan with the Meanwell 12V power supply.
    Page for the fan control here
    Prius OEM fan control - My wiki
    Could use an Inkbird Temp Controller ITC-1000F 12V, on Amazon $15, $22 in Canada.
    But the purpose is to run the fan full speed while pack charging so not sure why we would use a temp controller.
    #34 alftoy, Apr 9, 2021
    PriusCamper likes this.
  15. alftoy
    1,132
    510
    #35 alftoy, Apr 9, 2021
  16. fach
    fach Junior Member
    28
    24
    @alftoy, I agree with you! The schematics showed the 12v Meanwell power supply to feed the car fan. It has nothing fancy between the power supply and fan.
  17. fach
    fach Junior Member
    28
    24
  18. fach
    fach Junior Member
    28
    24
    I completed The Grid charger! I need to work in the discharge load section and cable to the traction battery.
    tangerino, PriusCamper and alftoy like this.
  19. alftoy
    1,132
    510
    Looks fine. OlRowdy grid charger illustrated build was mighty helpful.
    I got side tracked, water pump on the Rav4. 4 hour road trip to go babysit grand kids. Halfway back water pump started leaking, over heated engine, luckily friend 20 minutes away, got some water, filled and made it back home. Service manual said to remove engine???? Wth??? Rav4 world to the rescue. Still waiting for some parts.
  20. fach
    fach Junior Member
    28
    24
    Yes! The OlRowdy was super helpful! I still need to polish some details, but I like the product. I would do the timing belt simultaneously with the water pump in your Rav4, and I will get an original water pump! Good luck with the project!
    alftoy likes this.
