For Sale Wrecked Prius Killed A Deer, Clean Title
Discussion in 'Private Sales' started by PriusCamper, Apr 10, 2021.
  1. PriusCamper
    PriusCamper Senior Member
    13,053
    5,304
    Pacific Northwest, USA
    Located in 98502 area code. It's a 2010, has less than 100K miles on current engine and inverter is less than a year old and airbags are still intact. My buddy isn't going to file an insurance claim on this particular cab so he's looking for options to sell for parts or sell to someone for rebuild. The title is still in good standing for the moment.
    My guess is a shop will need to do some frame bending (main pillar on the left has been pushed back into the driver's part of the crumple cage a little) and the rest is just sheet metal bending and replacing body parts. More realistic / less effor is it's a parts car.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    if you end up parting out,I need the white fuse puller from the fuse box in the front, the switch on the lift gate and the plug that plugs into the lift gate switch. also if your glove box is black I need the top glove box.
  3. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    White fuse puller
    IG: twnzy_
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If this vehicle is ever parted out, we could use :
    • The passenger side windshield washer nozzle (interchangable?)
    • 55084-47020 The driver side lower corner plastic piece for the windshield o_O
  5. _xw30_chris
    _xw30_chris New Member
    29
    Socal 626
    I’ll take the windshield washer fluid reservoir
  6. TerryZ91
    TerryZ91 Junior Member
    Chicago, IL
