$300 OEM Toyota roof bars VS top-tier aftermarket?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by The Big Sleaze, Jan 5, 2020.
  1. The Big Sleaze
    287
    63
    'frisco
    2020 Prius
    Two Eco
    I've noticed some aftermarket bars are rated for a few more lbs max load than OEM (110lbs IIRC).
    How is the fit? (kinda important to me since my 2020 is my brand new "baby")
    How is the OEM VS aftermarket for R'n'R? (remove and re-install)
    Are the OEM bars some standard "aero" size that accepts a standard "Aero" interface from various aftermarket bike carriers, cargo-pods, etc?
    Yourfrienddustin likes this.
  2. Yourfrienddustin
    Yourfrienddustin Junior Member
    Phoenix, AZ
    Hey man! I just finished installing the oem bars and they are fantastic. I would say they are pretty similar to the aero type bars that have use a channel to lock in equipment.
    there is a little bit of noise at speeds over 65 but it’s not to bad. I have had used thule, Yakima and rhino rack on other cars and for the price it was no question to go Toyota oem.
    I carry to road bikes and a cargo box from time to time. Everything fits and no issues with weight
  3. Ron.in.Vic
    Ron.in.Vic Junior Member
    victoria, canada
    2019 Prius
    Technology AWD-e
    I've the OEM roof rack (2019 Prius) and was wanting to migrate my Yakima Kayak Saddles (Mako) from my old car. Toyota dealer here and Canadian office not very helpful. Even Rack Attack initially led me astray (but they did take up the challenge and found the same solution as I had). Initially, Rack Attack suggested and I bought Yakima's Universal MightyMount (They have discontinued the OEM-specific MightyMounts). But this would require 16 mounts and looked ugly! Someone had mentioned that Thule makes the Toyota roof rack, so...I did further research: it looked like XADAPT12 (Thule T-track accessory kit) would meet the need. The T-bolts are the perfect length and fit the channel snuggly. As well, the round hex nut is more secure than the Yakima-included hand-tighten wing nuts. (Not sure if I need a metal washer; any advice?)
    This seems to be a perfect (?) marriage of Toyota-Thule and Yakima. See photo (I still need to trim rubber that covers channel). P4100037.JPG
  4. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    We use t Track to mount our 1990 Thule weekender top box.
  5. MPGboss
    MPGboss Member
    Los Angeles
    2021 Prius
