New to forum -- ABS lights and brakes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by walter lazure, Apr 19, 2021.
  1. walter lazure
    walter lazure New Member
    memphis
    I
    Hi folks -- new to this site and thanks in advance.
    This may have been discussed before, but my daughter has a 2010 prius, great shape and only 109k miles. The ABS lights lit up on her dash and the brakes are mushy. Went to the dealer and he said the warranty on them just expired Feb 1st, and it will be 2700 to fix. Tried to talk to Toyota but no help.
    They reset the code and worked fine until about 40 miles later and the same thing, lights on and brakes mushy again. I then took it to my local guy and he had it down to 1700. He reset the code and again, no lights and breaks fine. But after a day, lights on and the car breaks, just not as good.
    They claim it's mechanical and booster and all will need to be replaced. Odd to me everything works fine when reset. I have to believe if it is mechanical, why not fail all the time and should not work for a while when reset.
    Any thoughts?
  2. ChapmanF
    18,569
    The lights on the dash are minimal information; they only mean the computer controlling the brakes has trouble codes it needs to give you, indicating what problems it is aware of.
    The dealer should have given you the codes. The local guy should have given you the codes. You should have given us the codes. :) If you don't have the codes yet, they should be got.
    There are scan tools available that plug into the diagnostic port under the dash and can retrieve the codes (and more detailed subcodes, and other information to go with them). If you don't have access to such a tool, there is a more primitive method where you can use a short wire between two pins on that connector, and count light blinks on the dash to get the codes. (Many threads here on PriusChat have the details.) You don't get the subcodes or other information that way, but you do get the basics. Not all computers in the car can blink codes for you that way, but the brake computer definitely can.
    There is nothing weird that it "works fine" when reset. The point of having a computer detect warning conditions is for it to be able to tell you about them while they are still warnings. When it detects the problem, it goes into a protective fail-safe mode (which is the change you notice in how the brakes feel). When you reset it, of course it will not be in the fail-safe mode anymore, until the next time it detects the problem and reissues the warning.
  3. rjparker
    10,549
    6,622
    If your mechanic just reset codes and did not change the brake pump and master cylinder yet, that is your next move. Especially since the dealer already diagnosed the problem. The dealer will change the brake pump and master cylinder with new parts. Verify what the second guy will do as some install used parts. There are no rebuilt parts available. Either way it is a labor intensive job. If you go used be sure to get a year or more parts and labor warranty. Negotiate pricing with either shop.
    Often the brake pump has to run excessively for a period of time before setting codes. It may still work but there is most likely nitrogen / air in the lines which is part of the failure mode. When it does fail completely there is a failsafe with no power assist and dramatically increased stopping distance. Don't wait for that day.
  4. walter lazure
    memphis
    I
    Thanks -- explains what is happening! I will not put on used parts for sure.
