Camry Issues Covid-19
Discussion in 'Toyota Hybrids and EVs' started by Alan2011, Jul 21, 2020.
  1. Alan2011
    Alan2011 New Member
    Harrisburg va
    2011 Hybrid Camry Black SE battery has been fully charged like the battery picture shows since I got the car in 2011. Which is good I think. The car only sat for 3 months while the virus was out. I haven’t reset the codes. Since I don’t have a code reader. I started the car on June 2nd. The fan in the back is super loud . I went back to work June 5th. I need the car again so I can work at Luray Caverns again but the car doesn’t seem to work as well as it did back in mid-2011 when I bought it. My Stevens Toyota in Harrisburg VA on July 18th and they given me the codes already. They want over 6,000$ or something to fix all of this which is super crazy. I’m in Harrisburg VA which is about 30 to 40 minutes to my work. I hope I didn’t damage the hybrid system or anything. I know I jump started the Camry with my neighbors jump starter when the auxiliary battery was dead back June 2nd. Any Options?
    P0A80 - Replace Hybrid Battery Pack
    P0A7F - Hybrid Battery Pack Deterioration
    P0A0D - High Voltage System Interlock Circuit High
    P0A0F - Engine Failed to Start
    P0A1F - Battery Energy Control Module
    P0AFA - Hybrid Battery System Voltage Low
    P3027 - Battery Block 17 Becomes Weak
    P3000 - Battery Control System Malfunction
    P0A1D - Hybrid Powertrain Control Module
    P0606 - ECM Processor Error
    P0604 - Internal Control Module Random Access Memory Error
    P0560 - System Voltage Malfunction
    P0516 - Battery Temperature Sensor Circuit Low
    P0420 - Catalyst System Efficiency Below Threshold
    C2318 - Low Or High Voltage Error Power Supply Malfunction
    C1242 - IG1/IG2 Power Source Circuit
    C1241 - Low Or High Battery Positive Voltage
    C1310 - Malfunction In HV System
    C1259 - HV System Regenerative Malfunction
    B1424 - Solar Sensor Circuit Driver Side
    B1421 - Solar Sensor Circuit Passenger Side
    U0111 - Lost Communication With Battery Energy Control Module
    U0100 - Lost Communication With Engine Control Module/Powertrain Control Module
    U0293 - Lost Communication With Hybrid Vehicle ECU
    52,383
    it was a good run, rip.
  3. ttou68
    ttou68 Active Member
    351
    211
    Congrats on 386K miles!
    It's hard to think about options without knowing the maintenance history of this vehicle, but I couldn't help to think that most of your codes other than Hybrid system and weak battery in block 17 are cause by dead 12V battery...
    I would suggest clear the code, and either buy a new 12V battery or charge up and load test current 12V, start and drive your Camry till the code comes back and see what's codes are left, then figure out your options...
    CamryDriver likes this.
  4. landspeed
    landspeed Active Member
    387
    209
    NZ
    2003 Prius
    I hope you checked the 12v battery, because that was definitely a big contributor. The older a hybrid gets, it has more chance of having ‘high drain’ on NiMH cells if left unused. My NWH11 had a good battery with two blocks having one bad module each; I left it 1 year - most blocks were down from 14v, to as low as 2.6v! So I’m rebuilding the pack with NWH20 cells.
    you probably had some excess self discharge in a single battery, and also a dead 12v battery. I hope you got it sorted!
    hill likes this.
  5. landspeed
    387
    209
    NZ
    2003 Prius
    (in a single cell, but technically each slice is a battery so...)
