Preventing Catalytic Converter theft
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by enginestarter, Apr 2, 2019.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,497
    Taylors, SC
  2. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    I emailed a Canadian eBay company and but they said they don’t ship to California.
  3. Georgina Rudkus
    3,511
    2,497
    Taylors, SC
    Yeah, C.A.R.B. rules in California only allow for OEM replacements on Prius cars.
  4. golfmk681
    264
    105
    los angeles, ca
    I know man..... ugh ‍
  5. Isaac Zachary
    Isaac Zachary Senior Member
    2,671
    1,380
    They only allow CARB certified parts. It just so happens no one has made a CARB certified aftermarket catalytic converter. The $100 ones don't go nearly as good as a job cleaning the air.
  6. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I was visiting family and traveling in Texas, so had Toyota of Cedar Park (near Austin) install it. I could have saved a lot of $$ by ordering it myself, and have a local shop install it, but I wasn't home. They charged $255 to install it, and $250.89 for the Millercat shield, $505.89 total. The Millercat lists for $160 on their website, so Toyota marked it up quite a bit. But the install was well done, and I've not had any issues with it rattling or anything. It gave me some peace of mind driving back home, stopping in hotels for the nights.
    Once home, I installed a tilt sensor and alarm. A thief might still steal the cat, but hopefully these make it a bit harder and noisier.
    #106 Terrell, Apr 22, 2021
  7. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Another option to add to the collection :
  8. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    In addition to an alarm with tilt sensor, which sets off a deafening alarm if the car is jacked up, I installed a cat shield and $100 deductible on comprehensive. And I made two of these magnetic warning stickers, one for each side. That should do it!
    gboss, edthefox5 and Isaac Zachary like this.
  9. Isaac Zachary
    2,671
    1,380
    I wonder if adding a bunch of steak knives pointing straight down would help.
    douglasjre likes this.
  10. Georgina Rudkus
    3,511
    2,497
    Taylors, SC
    view from front wide.JPG I placed these on the bottom corner of the back windows and painted the cat, the pre-heater, and the resonator with bright orange VHT header paint. catalytic converter engraved sticker.JPG
  11. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    There are non-flammable materials that blow up if you try to cut them with abrasives and others that catch, wrap around, shatter and break cutting devices
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Uni for the WIN!!!
  13. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Awesome! That sticker is the best. What type of tilt alarm did you install?
  14. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Any Amazon links?
    Isaac Zachary likes this.
  15. Isaac Zachary
    2,671
    1,380
    High pressure line of pepper spray and skunk juice running along exhaust would be nice.
    Another likes this.
  16. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Actually tried to edit my original post, but the window to edit lapsed. I didn't get the tilt sensor but had planned to. I couldn't find a place to do it within my budget.
  17. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Which aftermarket cat works well enough to keep the CEL from turning on?
  18. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    Almost all of them
    main problem is if your in a carb area that mandates OEM
  19. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    walker or magnaflow. seen piles of others set P0420.
  20. Another
    1,819
    517
    Naples, Florida
