"Something" on / from rear beam has snapped. What is it? Picture attached.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusdonegal, May 1, 2021.
Tags:
  1. priusdonegal
    priusdonegal New Member
    ireland
    please help identify this part that has snapped. Located on rear beam near brake system. Doesn't look too complicated. Don't know what it is so can't search for advice in the forum. Connected to brake system? Small part, held on by x2 #10 nuts. Thanks for any help.
  2. ChapmanF
    18,552
    Headlight leveling sensor.
    priusdonegal, RRxing and Mendel Leisk like this.
  3. Mendel Leisk
    41,908
    It’s very worthwhile to disconnect one end of that every few years, flex the ball joints beyond the tiny movement they usually do, redistribute the grease.
    if you can get the ball joints lubed and freed up, a funky splint on that broken arm might work as a stop gap fix. Say a tight fitting section of vacuum tube pushed on both sides of the break, and small screw band clamps to keep it tight. Maybe fill the tube with JB Weld too.
    #3 Mendel Leisk, May 1, 2021
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    As ChapmanF said, it's a sensor that measures suspension height so that a computer can properly adjust the headlight up and down aim. The bracket at the bottom and the sensor arm on top both have metal ball studs. The plastic link has ends that snap over the studs. Over time the ball studs rust up and cause the plastic link to seize instead of swiveling when the suspension moves. Eventually it breaks.
  5. Mendel Leisk
    41,908
    Toyota should recommend an occasional inspection of that; it’s a heck of a lot more failure prone, than the driver’s floor mat for example.
  6. ttou68
    ttou68 Active Member
    351
    211
    Looks like headlight leveling sensor link has broken... here's an image of complete sensor with housing and Link circled. Screenshot_20210502-100920_Chrome.jpeg
    #6 ttou68, May 2, 2021
  7. Mendel Leisk
    41,908
    Yeah the ball joints seized at the ends of that link seized, so something had to give.
    At least on 3rd gen, probably also on 2nd: you can crawl under without even jacking it up, disconnect the bolts at one end, move those joints through fuller travel, redistribute the grease.
    priusdonegal likes this.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,856
    850
    Southern California
    Hmm, this thing measures suspension height? Anybody know how it works and what the pin signals are? Folks have been attaching tilt sensors to the alarm system to protect cats. Surely the suspension height must change significantly on the side of a car which is jacked up. It looks like a fairly pricey part, but if it is already on the car, maybe it isn't too hard to power it up when the car is off and read its signal?
  9. ChapmanF
    18,552
    There's just the one, and it's sort of in the middle of the rear axle beam; it's mostly there to detect angle front-to-back, as you would want for headlight leveling.
    I'm sure the reading would still be likely to change with one side of the car being raised, so maybe it would be usable ... it's just not positioned best for that purpose.
  10. priusdonegal
    ireland
    Thank you for quick reply.
  11. priusdonegal
    ireland
    Thank you
  12. priusdonegal
    ireland
    Thank you
    ttou68 likes this.
