Wind Chill Pearl Touch up
Discussion in 'Prime Accessories and Modifications' started by ETP, May 7, 2021.
  1. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    #1 ETP, May 7, 2021
  2. Elektroingenieur
    2,515
    3,253
    Three Touring
    There are two separate codes there, listed on the certification label as “C/TR: 089/EA20.” The exterior paint color (C) code is 089, Wind Chill Pearl (also called Platinum White Pearl Mica), and the interior trim (TR) code is EA20, black SofTex material.
    For paint color code 089, there are two touch-up paint applicators: Toyota part number 00258-089BC-21 for the base coat, and 00258-00089-21 for the top coat.
    ETP, Tideland Prius and Mendel Leisk like this.
  3. Mendel Leisk
    38,197
    They don’t make it easy; you need a code to read the code.
    ETP likes this.
  4. ETP
    2,799
    1,170
    Auburdale FL
    Thanks all! I did notice that the old Pearl white {070} is very close in color
