Electric only range
Discussion in 'Gen 3 Prius Technical Discussion' started by //go_prius_2, May 11, 2021.
  1. //go_prius_2
    //go_prius_2 Junior Member
    I can travel about 2 miles in my 2010 Prius before the traction battery is really low, and the ICE kicks in. I thought the range in electric mode was more than this. The car has 154k miles and does not show any CEL.
  2. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    whats your estimate distance should it go?
    Maarten28 likes this.
  3. bisco
    48,974
    i have never even seen 2 miles, is that downhill :p
    Threej and Maarten28 like this.
  4. bisco
    48,974
    btw, don't drive in electric, you're gonna kill the battery and your mpg's
    Threej and jerrymildred like this.
  5. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    oxymoron
  6. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "btw, don't drive in electric, you're gonna kill the battery and your mpg's"
    Right, and oh, while you're at it, please do yourself a favor and READ THE OWNER'S MANUAL:
    Direct link to download the PDF for Quick Reference Guide
    Direct link to download the PDF for Full Owner's Manual
    (for 2010 Prius)
  7. Mendel Leisk
    38,242
    OP, don’t answer this, he’s only trying to add you to his quotes of shame.... :D
    Threej, bisco, Grit and 1 other person like this.
  8. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    why you little...
    bisco and Mendel Leisk like this.
  9. Maarten28
    Maarten28 Active Member
    414
    223
    Netherlands
    2 miles is really the max. The battery is about 1.3 kWh and from "normally full" to empty is from 60% SOC to 40%, so only 20% of the capacity. That's about 0.26 kWh and it is a stretch to get 2 miles from that.
    Maybe you're confused with the plugin Prius which will get some 10-15 miles of electric range.
    Threej, //go_prius_2 and jerrymildred like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    As @bisco and @Maarten28 said, don't try driving in EV. The only good use for EV in any Prius except the PiP or Prime is when you just want to move the car a few feet and don't want to start the engine. In normal driving let the car decide when the engine should run. You'll get better gas mileage and the traction battery will wear more slowly.
    And unlike most cars, the Prius owner's manual is way more than just a kneeling pad. There's a lot of important stuff in there beyond just this subject that will make you and your car happier.
    ASRDogman likes this.
  11. //go_prius_2
    I stand corrected. I would swear that I saw somewhere that the range of EV mode was 14 miles. It probably should be closer to 1.4 LOL
  12. Tideland Prius
    16,072
    Perhaps you were looking at the PiP (Plug in Prius) that has the same body style as the 3rd Gen Prius.
    Mendel Leisk and jerrymildred like this.
  13. fuzzy1
    10,044
    That is twice as far as the original marketing hype in 2009 was claiming.
    Back then, Toyota was saying 1 mile. But since it really isn't an electric car, and the electric-only speed limit is just 10 or 25 mph depending on engine coolant temperature, it seems they've dropped even that claim.
  14. ASRDogman
    ASRDogman Senior Member
    5,903
    3,167
  15. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    so you’re going to sell it and get a plug in?
