Parking on a slope Driveway - Makes a thud noise when shift to Drive or reverse gear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mushtaq M, May 10, 2021.
  1. Mushtaq M
    Mushtaq M Junior Member
    Glasgow
    Active
    I park my Prius on my slope driveway . Every morning when i start my prius and change the gear to Drive mode or reverse it makes a audible thud noise. But changing from park to drive on level roads any where on a level area is alway smooth suggesting there is no issue with my CVT Transmission and the slope may be causing a problem.
    Is there a problem in parking on a steep driveway for example what worries me is the CVT Transmission fluid is not level on a slope and could be causing a rough shift in mode?
  2. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    do you engage parking brakes parked on the slope?
    #2 Grit, May 10, 2021
  3. ASRDogman
    ASRDogman Senior Member
    7,493
    3,882
    If you put it in neutral, set the parking brake, release the foot brake, then press the "P",
    you might not get that. "if" it is the transmission.
    Mushtaq M likes this.
  4. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Probably the weight of the car resting on the parking pawl.
  5. bisco
    51,715
    have you checked the fluid level?
  6. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Do you put it in park, release foot brake, and then set the parking brake? In that order?
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Probably. But that is the wrong order.
    sLick415 likes this.
  8. AW82
    AW82 Member
    186
    99
    Madison, WI
    This. Happens on just about every automatic transmission when parked on a slope without the hand/foot/emergency/whatever brake applied. I think far fewer people would experience this if automakers either went back to hand brakes or electric parking brakes that activate anytime the transmission is shifted to park. I rarely use the foot brake on either of our cars (unless parked on a slope) because "the other person" that drives these cars has a really hard time remembering to release it. It's almost like there isn't a big red light on the dashboard...
    Samuel Williams Jr likes this.
  9. Mendel Leisk
    41,146
    More like a wee red icon. I recall lamenting the lack of warning, years after getting our 2010, and someone here pointed out there IS an alert, albeit easily overlooked. I’ve got a vague recollection it beeps too, or is that a false memory?
  10. AW82
    AW82 Member
    186
    99
    Madison, WI
    Well, I was talking in general. I've not seen her do it in the Prius more than once, but our Honda has a fairly noticeable light and definitely beeps. She notices when the Honda starts beeping, but that's usually after 5-10 seconds of flooring it trying to get the car to accelerate.
  11. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    add “tire shop employees” on to the list also. They drove my vehicle with parking brakes half engaged, it was like nails scratching on chalkboard. The red BRAKE led was lit on the dash, but dash lights are only suggestions.
  12. privilege
    privilege Active Member
    659
    169
    Birmingham
    once you watch a few YouTube videos of "how parking pawls work" you'll understand why the parking brake is there, and when to use it
  13. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    no way, sum it up for us in one sentence. we can’t stray off of netflix.
    Samuel Williams Jr and privilege like this.
  14. bisco
    51,715
    don't park on slope
  15. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    You use cheaper parts to bear the weight of the car instead of increasing wear on expensive ones...
    Grit likes this.
  16. AW82
    AW82 Member
    186
    99
    Madison, WI
    Apparently those of us that take 3 seconds to scan the instrument cluster and check mirrors after starting the engine but before putting the car in gear are uncommon.
    Samuel Williams Jr and bisco like this.
  17. Mendel Leisk
    41,146
    Traditional handbrake lever in centre console is harder to miss?
    Grit and AW82 like this.
  18. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    This happens with basically every auto transmission car I’ve ever driven. It seems to help if I apply the parking brake to hold the car in place while changing gears - put it on before shifting to P and wait until after shifting out of P to take it off.
    privilege likes this.
  19. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Everyone should be using parking brakes even when parked in flat terrain. Imagine if your parked car gets hit directly in the back or front, the parking paw restricted the car from moving back or forward. With out parking brake on, your transmission could go kaput.
  20. sam spade 2
    7,035
    2,801
    2017 Prius c
    Not sure that makes any sense.
    The parking pawl works kind of like sticking a broom stick into the spokes of a bicycle.
    If you try to move it, something breaks.
