Radiator Fans ON & OFF at Full Speed when AC is Turned ON
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by e30is, May 12, 2021.
  1. e30is
    e30is New Member
    US of A
    Hello everyone,
    I am experiencing this weird issue with my 2013 Prius were the radiator fans would turn on and off continuously at full speed when the AC is turned on and the blower set to max speed (Video details on YouTube below). Also, if I set the blower speed to one bar, the fans would run at full speed without switching on and off. I have checked all AC related fuses and relays and all are working fine. I have swapped the 3 fan relays with my other 3rd gen Prius that is working perfectly.
    The car has been involved in a front driver side accident, so the condenser, fans, radiator were all replaced from a donor car. The AC system didn't have gas left in it so I went to charge it and noticed the fan speed issue. The AC blows cold and there are no issues on that.
    If anyone has any idea what should I check next or have encountered similar situation, your help would be greatly appreciated!
    Since I can't upload the video link here, please search for
    "Toyota Prius 3rd Gen AC Fans Full Speed ON/OFF When AC is ON" on YouTube
    Channel name starts with e30
    Thanks!
    #1 e30is, May 12, 2021
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Here in Pc, it’s obsolete to do searches. You have to feed it baby bird style for us.
  3. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
  4. lech auto air conditionin
    830
    605
    261
    san francisco
    I got to say that one stumped me I’ve never seen that one before.
    Lucky you you win the prize. Lol
    can you tell through vibration or sound is the compressor also turning off and on constantly ?
  5. e30is
    e30is New Member
    US of A
    Thank you sir for putting up the video!
    Yes, I can hear the compressor turn on and off as well. There's gotta be a switch or a sensor somewhere that is causing this issue, don't you think?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Get Techstream or similar capable scantool and see what the A/C system data is (what is the high pressure sensor displaying?)
    When you had the system recharged, how long was it evacuated beforehand? How and who recharged it? What were high and low side system pressures after recharging?
    If there is still air in the system or it was overcharged (or a bad pressure sensor makes it think the pressure is too high) then you could be "bouncing" off the system's high pressure cutoff point. That would also explain the high radiator fan speed.
    You need to know what the pressures ARE and what the ecu THINKS they are.
  7. Zavnet
    Zavnet Junior Member
    Jamaica
    Did you solve this issue? I am having the same problem... Mine got a front end crash and was repaired and is now exhibiting the same problem.
  8. lech auto air conditionin
    830
    605
    261
    san francisco
    Yes I believe you are correct I forgot about people grossly overcharging the Prius and it instantly going in the 400 psi banging on the fans immediately into high speed and then going over 440 psi in immediately cutting off the compressor.
    The pressure falls down cuts back on the compressor immediately high speed fan then immediately cuts off the compressor again and keeps repeating the cycle.
    I’m banking on your one decision that somebody overcharged it it only takes two or three extra ounces to do this as I released a video before showing over 400 psi with two extra ounces of refrigerant
  9. ChapmanF
    18,463
    Prii have a nifty way of wiring the two fans, where there is a low speed achieved by putting the two in series across the 12 volt supply (so each fan sees 6 volts), and a high speed achieved by paralleling them (each fan sees 12 volts). The series/parallel connections are swapped around by the three fan relays.
    You can search up some existing threads here that include that wiring diagram.
    It not uncommonly happens, in repairing a front crash, that somebody misses a detail of that wiring, usually the series connection for the low speed, and then the result is the fans don't operate on low. That means they're not cooling the A/C at all when the controls want them on low, and as a result the controls will keep bumping them to high when the pressure or temperature rises, and then back down to low (where again they don't run at all).
    A similar thing can happen if one fan just doesn't work. Because low requires both fans in series, there won't be any low if either fan doesn't work. Then the system will keep bumping to high, where only the working fan will work.
  10. rjparker
    10,415
    6,522
    I am going with the overcharged theory. Screwing up the fans' series wiring while preserving the parallel wiring seems less likely. Especially if both run in High.
    Low is with Relay 3 Pulled In
  11. ChapmanF
    18,463
    It's a pretty recognizable syndrome when it happens though. No low-speed operation, which means the temperatures and pressures quickly spike to the trigger point for high speed, and then decrease again quickly with the high fans. So instead of just running nicely on low, the system repeatedly bounces between high speed and no fans.
  12. PriusG909
    PriusG909 Junior Member
    17
    Los Angeles/IE
    Any fix to this issue I seem to have it too after a new motor was installed.. any help would be appreciated
  13. ChapmanF
    18,463
    Fix will depend on what's causing it, not always the same. If you grab a meter and follow the wiring diagram above, shouldn't take too long to pin down.
  14. Zavnet
    Jamaica
    I found out my cause. 1. the drier bag was filled with oil. and after that, it did the same thing with fans running on full blast, which turns out to be overcharging of the system. once the right amount went in. the fan speed cut down, and a/c blows cold.
    PriusG909 likes this.
  15. Adrien
    Adrien Junior Member
    17
    France
    Hello everyone I have the same fan problem always at high speed and non stop when cold setpoint since I put gas with duracool 12a, what should I do? It looks like the pressure in the high-pressure circuit is too high.
  16. rjparker
    10,415
    6,522
    Evacuate, vacuum and recharge by weight. Ensure variable speed compressor is on full.
  17. lech auto air conditionin
    830
    605
    261
    san francisco
    I wonder if everybody will ever eventually learn there’s only one correct way that works 100% of the time that gives you 100% correct results that gives you 100% factory performance.
    No, guessing
    No estimating
    No, I think
    No, it works most of the time excuse
    Just a simple Evec and recharge by weight only with no exception to that rule
    It only takes about 15 seconds to completely recharge with liquid refrigerant in a Prius every time all the time 100% of the time no excuses accepted.
  18. Adrien
    17
    France
    Ok can air conditioning specialists do that? Most of the time it's a refill
  19. Adrien
    17
    France
    I checked the speed of the compressor fan, it goes to 6500rpm for a low setpoint, the motor fan runs constantly and at 20 degrees Celsius it runs intermittently. Can we have more information with techstream? I have no possibility of having it immediately but if it is useful I will manage. No error code goes back so high pressure flow not high, or below the max range?
  20. rjparker
    10,415
    6,522
    Yes a specialist can do it. These ac systems are nothing like most standard vehicle systems. Be sure existing gas will be removed, new gas is weighed in and they understand it is a variable speed compressor. It MUST use special oil, not standard poe or mineral oil.
    It should not be a hydrocarbon based refrigerant with additives like duracool 12a. Use R134a if that was originally used.
    It is not exactly clear what your symptoms are based on your posts. We don't know the year or model.
    Describe parts as radiator fan, compressor and evaporator (cabin) blower. Is it cooling well? How do you know its high pressure?
    #20 rjparker, Jul 19, 2023
