Toyota Prius front battery sorted/sparked during jump start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kylix3511, May 14, 2021.
  1. kylix3511
    kylix3511 Junior Member
    Hello All,
    My Prius is not started and drove for 6 months. Today when trying to jump-start the front battery ( The one charge to open the boot ). it suddenly sparked and didn't help to jumpstart the car. Finally, some able to open the front door and claw into the boot door and jump-start the car with lots of pains.
    it took a full hour to charge the back battery and finally, I can able to start the car.
    After an hr later, i drove the car for 30 mins, during that time, I noticed my back seat/door windows are not working. I can't open and close.
    Then after 30 mins drive, I parked the car and again battery died.
    I believe the back battery is fine but the front battery is failed or sorted the computer inside.
    Did anyone face this issue before? If so, what is possible to repair it? or just need to replace it?
    Please kindly help me and advise me regarding this issue.
    Thanks.
  2. rjparker
    10,350
    6,475
    We hear this story every few days. Your 12v battery is history and is in the back. There is no front battery. Replace the 12v battery.
    This did it. Never let it sit for more than a week. If you ABSOLUTELY have to let it sit for months, buy a Battery Tender Jr and keep it running 24x7.
    By the way, placing the charger up front and waiting as is effective asvcrawling through the boot to charge and wait back there. What happens in either scenario is the car's 12v battery is so low in voltage that it drags the charger voltage down.
    #2 rjparker, May 14, 2021
    ydpplqbd likes this.
  3. Mendel Leisk
    41,747
    You might be sending OP on a wild goose chase, depending on where in the world they are. English doesn’t seem to be their first language.
    Yeah a “smart” battery charger, one that can be left connected constantly, with around 3~4 amperage rating, would be ideal.
    This assumes access to suitable power source. If that’s not possible, and the car will continue to sit for long times, then either disconnect the 12 volt battery negative cable, or remove the battery from the car and periodically charge.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    To repeat a really important point here:
    There is only ONE 12 volt battery.
    Likely that it needs to be replaced.
    After that, you can see if you blew any fuses by making a mistake during the first attempt at jumping.
  5. bisco
    52,187
    from my foreign language class in high school, i am deciphering the 'front battery' as the jump point under the hood.
    if that is the case, it is just a wire to the battery in the hatch. it is possible that there is a problem with the connection, but unlikely unless rodents chewed it.
    why do you think the battery in back is good?
  6. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    There is no way to repair an old 12-volt battery allowed to be fully discharged for that long. Corrosion builds up on the plates and its ability to retain a charge is lost. It must be replaced.
  7. kylix3511
    Thanks all. Now I worried .. its jump point under the hood or the 12 volt battery at the trunk needs to change? In the jumppoint is battery or something else? Please advise.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The "one and only" 12v battery is located in the trunk at the rear passenger side corner. The "+" terminal of that battery has a heavy cable connected to it (plugged in to the black box) and the other end of that cable is bolted to the underhood fuse box. Where that cable is bolted to the underhood fuse box IS the jump point. This is where 12v battery power is distributed to all the other 12v systems in the car.
    Samuel Williams Jr likes this.
  9. bisco
    52,187
    how to test:
    measure the voltage at the battery with the car off, and then at the jump point. if the jump point is similar to the battery, it's the battery.
    how old is it? do you drive the car frequently? if it is 12.5 volts or better, it may be okay, but you need a load test.
    turn on the headlights for 5 minutes, and record how much it drops.
  10. Samuel Williams Jr
    246
    Dayton NV
    This should help.
    The 12 volt battery as has been stated," is in the rear of the car." The front jump point is for convenience, if you have to jump the car. It is electrically tied to the battery so you don't have to go into the back to jump start the car. For what you need to do, just forget it's there for now. :)
