Curious about MPG in cooler weather
Discussion in 'Gen 2 Prius Main Forum' started by Seagull6, Oct 26, 2006.
  1. Seagull6
    Seagull6 New Member
    42
    I live in NJ and have had my 06 Prius since mid-June. Up until last week my overall calculated MPG was around 52.6 and the MFD MPG was close at around 52.1 (my log book is in the car and I am operating from memory right now).
    The problem is that since the weather has become cooler (between 45 - 55 degrees) my MPG has dropped to 48.5 MPG. My driving habits are identical to before and the only thing that appears to have changed is the temperature, however, a friend suggested that NJ may have switched to the winter blend of gasoline alreay. I recall that in my other vehicles my mileage took a hit when we switched to MTBE gas, but I don't think they use MTBE here anymore. Incidentally, I checked my tire pressure and they are at 42 front and 38 rear. I'm using the same gas stations as before as well.
    Any ideas what's happening to my MPG?
  2. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    I've had the same happen to me. I live about 30 miles from you, and I'd been averaging around 49 MPG since I bought my Prius in April, but my last tank was a little over 44. That fillup was a little over 3 weeks ago, but the first week I was getting my usual mileage. I dropped a lot once we started getting mornings in the high 20's or low 30's and I HAD to use my defroster. I'm assuming it's because of the cooler temps and the need for the defroster. I'm 100 miles into my current tank and the MFD says 48, but it's been slightly warmer in the morning - high 40's and low 50's. Since my trips are relatively short, I'm pretty sure I'm seeing this much of a drop because of the temps - it takes longer for the car to 'get warm'.
    Like you, I check my tire inflation regularly, and most of my gas has been from the same station.
    I know we don't use MTBE in New Jersey, but there may still be some sort of 'winter blend' that's also playing into this.
  3. daronspicher
    daronspicher Active Member
    1,208
    I dropped off too... In Chicagoland... Seemingly am in the realtime 46-48 range now rather than my 52-54 in the summer.
    It sure seemed like a sudden drop off too.. I thought it would be gradual.. a mpg here, one there... it pretty much just dumped in one weekend.
  4. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Two reasons...
    1) The Prius gets less gas mileage, 25-35 MPG or so, until the engine is warmed up. This usually takes around 5 minutes in the summer. In the winter, the engine begins at a colder temperature, so it takes longer to warm up, and therefore the warmup mileage hit is a greater percentage of your commute.
    2) You are undoubtedly using the heater these days. The heater uses the engine's warmth to heat the cabin. In order to work, the engine must be hot and the engine doesn't get hot if it's not running. Therefore, until the engine warms up enough to provide cabin heat, it stays on, even when you are stopped at a traffic light. This lowers your mileage.
  5. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    That's normal. You'll learn to adapt... and then understand why the veteran owners all gravitate toward LIFETIME data. It's the only thing that takes seasonal cycles into full account.
    This is the 7th time I've experienced a Winter drop. It brings an entirely new meaning to the arrival Spring.
  6. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    I got my prius in june and had my best MPG tankfull av. in early oct (55.5).Its starting to slip now! last tankfull was about 52.Im interested on how low it will go this fall and winter before bottoming out.Putting snow tires on in early dec.(michelin x-ice),not sure how much additional mph hit that will give me.I know that other pc members have enigine heaters for the winter.Just wondering on how much that helps in relieveing the mpg cold weather hit? <_<
  7. meezercat
    meezercat New Member
    115
    <div class='quotetop'>QUOTE(daronspicher @ Oct 26 2006, 05:46 PM) [snapback]338909[/snapback]</div>
    I'm so glad you said this. I too went from 52-54 to 46-48. I'm attributing it to winter gas formulation (assuming they must have changed it) since it happened immediately after a fillup.
  8. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    <div class='quotetop'>QUOTE(Marlin @ Oct 26 2006, 05:49 PM) [snapback]338910[/snapback]</div>
    Add to this
    3) The engine cools off faster when stopped or running electric so it simply runs more to stay in the proper temperature range. The last half mile of my 4 mile commute to work is driven on campus with a low speed limit. I can almost always run it electric in the summer, but the engine will start towards the end in the winter. (A side effect is that the battery will have a higher level of charge than in the summer.)
    4) The winter gasoline blend has more additives and less energy. All cars get lower gas mileage in the winter, just not a big a hit as HSD cars.
  9. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    You lose a little mileage in winter from winter fuel, slush and snow on the roads or even sand. More rain can hurt too. The other reasons are a cold battery and faster cool downs.
    If you lose more from the other factors like a cold engine it is because you have not winterized your car and equipped your car with proper instrumentation.
    If you don't use a block heater you will lose lots of extra mpg for the first 5-10 minutes. So this item is most critical for those with short trips!
    If you don't have gauges and a properly set winter front the car will never even get close to warmed up on any length trip unless you drive very fast.
    When I got my car I started out at 55 or better mpg. As temps got down below 50 degrees my mpg dropped to 50. When temps dropped to 10 degrees F my mileage was down to like 35 mpg.
    The second year I added gauges and instruments. Now I still get mostly around 55 mpg summers. And in winter at temps down to 0 degrees I stay over 48 mpg. with at least dry roads. All that is required is to keep the engine up to normal operating temperatures but not allow overheating.
    I use canview for instruments. Convenient, easy and complete enough for even monitoring the motors as well as the engine. Before that was available I used the scan gauge that at least measured the most critical item: engine temperature.
    All this is covered in other threads, but it may not be so clear how very much this stuff affects winter mpg.
    With the gauges I could see before I had any winter front, my engine temps would be maxing out at 120 deg F instead of a normal 170-190 degrees. when I was doing city type driving. This not only gives bad mpg but keeps the heater and defroster from working very well at all.
  10. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Now, you know what they say about assumptions.... LOL. Personally up here in MN, i have yet to use my heater once (just the defroster for a few seconds to clear the window when it fogs up) And yes, it has been rather chilly here lately...
  11. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    One of PriusChat's administrators is TonyPSchaefer. He has a wonderful chart on his signature which shows in graphic detail what happens to mileage when temperature changes. A picture is worth a thousand words. Here it is:
    To see his entire data about this go here
  12. tmgrl3
    tmgrl3 Member
    315
    I'm waiting for this to happen.
    I live in same "weather zone" as NJ....my mpg for last few tanks (I only have 1200 miles) has been 42 mpg.
    The current tank is at 46 mpg despite cooler weather (not cold by any means). My tire pressure is down a bit as well...I had it at 40/38. Checked recently and it was 38.6 front...so need to up that again.
    I figured the car was breaking in.
    Also, I filled up this tank when the ICE was already warmed up....somehow, I was just able to maintain a bit higher mpg. this time...no changes in my driving patterns...although I am allowing the stealth mode to kick in when car "wants" to, instead of fighting for glide....I have lots of long downhill coasts that charge up the battery, so
    maybe the car is just bleeding off some of that electric power stored.
    Also, I am driving at a more steady pace...up and down my hills instead of going up briskly...and trying to stay in the zone for glide. Seems to be working for me.
    terri
