Prius c one 2015 oil filter tool
Discussion in 'Prius c Main Forum' started by LBC12, May 16, 2021.
  1. LBC12
    LBC12 New Member
    Long Beach
    2015 Prius c
    Hi. I need help getting the right tool to remove oil filter on my 2015 priuc c one. Any help will be apreciated it.
    Thanks
  2. Mendel Leisk
    41,640
    Honda, but it works, for any and all 12 flute, 64 mm face-to-face. Had mine for maybe 30 years, used on Honda, Toyota, and Mazda. It’s heavy gauge stamped steel:
    07AAA-PLCA100
  3. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Hypertough #4207, under $5 on shelves at most walmarts.
  4. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    I did a DIY oil change for the first time on my 2014 last week and used these pliers to loosen the filter.
  5. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    ^ Those are my usual. I've done my c with those, but it's a bit more awkward than the cap socket.
    Pri3C likes this.
  6. Mendel Leisk
    41,640
    You can’t use the torque spec (13 foot pounds) with the pliers. There is an alternate 3/4 turn past first contact spec as well. And yeah I know: everybody “in the know” just hand-tightens.
    Pri3C likes this.
  7. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Yeah, it was awkward. I found it was easier to loosen from the bottom with the plier handles pointing down instead of trying to do it the proper way from the side. The clamps are nice and grippy, though, so both methods work.
    @Mendel Leisk good point about torque spec. I think I just hand tightened and maybe used the pliers a little. Since this was my first oil change, I’ve been periodically checking underneath for leaks. It’s looking good so far, but it’s certainly not a bad idea to use a tool that will torque the filter to the recommended spec.
    #7 Pri3C, May 17, 2021
  8. Mendel Leisk
    41,640
    I’ve put a mark on the filter end, say at 6 o’clock, then torqued to 13 ft/lb, and the mark ended up around 3 o’clock, which means the two torque methods jive.
    but yeah, I know I’m belabouring: the aforementioned Honda filter socket is readily available and will outlive you lol. A little pricey, around $35 USD IIRC.
    Pri3C likes this.
