2009 Gen 2: tire inflation light won’t go out
Discussion in 'Gen 2 Prius Technical Discussion' started by jbean, May 18, 2021.
  1. jbean
    jbean Junior Member
    78
    I added air in my tires and the dealer reset the tire inflation light but it still stays on. Does anyone know if this is a big deal to troubleshoot and fix?
  2. dolj
    dolj Senior Member
    7,505
    3,772
    Wellington, New Zealand
    Start with reading the codes and looking at the TPMS live data. Hopefully, with this information, it will be clear where the problem lies.
  3. jbean
    jbean Junior Member
    78
    I should have mentioned, I’m not a DIY person so someone else will be troubleshooting. Just wondering if this could be an expensive repair.
  4. dolj
    dolj Senior Member
    7,505
    3,772
    Depends on what is wrong. I'm leaning towards one or more of the TPMS sensor batteries that has/have gone flat.
    They are expensive for what they are, but it would be cheaper if you change the sensor(s) when you next change your tires.
    Reading the codes will let you know for sure.
    Raytheeagle likes this.
  5. jbean
    jbean Junior Member
    78
    I’ll find out tomorrow if I need new tires. Why would it be cheaper to change the sensors at that time? Because of the location of the sensors?
  6. dolj
    dolj Senior Member
    7,505
    3,772
    Yes, the tires need to be deflated and moved out the way to replace the sensors, so it is no extra labor to do it when you change to new tires.
    To be clear, you do not need to change your tires if there is still good tread left. Just wait until they are worn out and then put new sensors and tires at the same time.
    Skibob, Raytheeagle and jbean like this.
  7. jbean
    jbean Junior Member
    78
    Thank you so much for your help!
    Raytheeagle and dolj like this.
  8. 120m256
    120m256 New Member
    17
    Arizona
    @jbean here is your $1 fix:
