Replaced 12v battery - MPG increased - another anecdote
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yossi, May 17, 2021.
  1. yossi
    yossi Junior Member
    61
    I recently got a 2008 with 189k miles. The 12v was original. I was not having any issues, no dash lights or any indication the battery was failing, but when I ran the on screen diag, it showed it at 10.7 volts. So I had the dealer replace it with a new Toyota, $250 out the door. My average MPG has gone up from around 43 to around 48. I notice the car lasts longer on hybrid battery only, especially when I have cruise control engaged on a flat road and locked in at 35-40. Just wanted to share my experience.
    49,448
    that's amazing!
    1) 13 year old oem still working
    2) dealer install for $250.
    3) mpg increase
    4) you hit the trifecta!(y)
    yossi likes this.
  3. Mendel Leisk
    38,710
    Maybe. How would you know for sure? Either way, it was time. :)
  4. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    A long time ago I had a Sears Diehard last 10 years in my 1987 BMW 325i. When I looked in my glove compartment for my battery paperwork, I found the 10-year-old paper and just assumed that since the battery could not possibly have lasted that long I must have mislaid the more recent paperwork. But when they took my old battery out of the car they pointed out that there was a manufacturing date code on the battery which was consistent with my approximately 10-year-old timing. So far that is my lifetime best battery time.
    Is it normal for automotive batteries to carry a manufacturing date code these days?
    Valiant V and Mendel Leisk like this.
  5. Mendel Leisk
    38,710
    I’ve heard yes, but sometimes it’s a code, maybe to discourage “cherry picking”, like when you’re buying groceries, looking for the latest best-by dates.
  6. yossi
    yossi Junior Member
    61
    Dealer confirmed based on manufacture date on battery.
    bisco and Mendel Leisk like this.
  7. bisco
    49,448
    toyota date code is on top, and not really a code, just the date in numbers and letters.
    you do have to remove the hold down bracket to see it
  8. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    Just numbers actually in the format ddmmyy.
  9. Pdaddy
    Pdaddy Member
    153
    49
    Warmer weather has a significant positive effect on efficiency
    SM-G960U ?
  10. Grahams Number
    Grahams Number Junior Member
    Douglasville,Ga
    Another thought...unplugging battery reset engine ecu. I *think* the ecu learns your driving style and specific engine parameters. It will take several days to relearn
    #10 Grahams Number, May 20, 2021
