1. texastoyota1939
    texastoyota1939 New Member
    texas
    Does anyone know what the oil filter number for a Mobil 1 to fit a 2011 Toyota Prius. I did get a number from a local parts house of M1-C154. I cannot find that number anywhere on the internet.
    Thanks
  2. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    There are to Mobil 1 filters that will work one is M1-C154 and the other is
    M0980
  3. Mark57
    2,945
    2,738
    OK
    The 2011 should be the same as the 2010. The 2010 uses a Toyota Oil Filter Kit (04152-YZZA6)
    which is a paper cartridge & rubber O-Ring and it takes a 65mm filter wrench.
    There should be a crossover for Mobil 1. I thought having the Toyota number might come in handy in the future even tough that's not what you asked for.
  4. stefano5777
    stefano5777 Member
    380
    47
    If you go to Mobil 1 web sight and go to catalog and enter all your vehicle info it will show you the two oil filters.
  5. john1701a
    john1701a Prius Guru
    12,802
    5,285
    57
    This document describing the oil-change process for the 2010-2011 provides a photo of the element kit (paper filter insert and gasket).
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
  7. laki007
    laki007 Junior Member
    25
    Poland
    What is the plastic piece?
  8. Hugh G. Wreckshin
    Hugh G. Wreckshin New Member
