2021 Annoying slow speed noise
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, May 18, 2021.
  1. fuzzy1
    10,555
    At higher speeds, tire-pavement noises are significant, so no added noise is, er, uh, "needed", so are allowed to be turned off.
    If this noisemaker law were really rational, it would set a minimum noise level for all cars, regardless of power source, even traditional ICEs. While most ICEs would pass without added noisemakers, it seems that a not insignificant number of modern ICE cars, engineered to be as quiet as practical, would already be flunking this requirement. Excluding them from noisemaker requirements is discriminatory.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I thought about mentioning this earlier but didn't take the time. I've been surprised in parking lots a number of times by dead silent ICE cars behind me.
    fuzzy1 likes this.
  3. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    It's another hole in the "study" of the dangers of EV vehicles. I am relatively frequently almost the victim of inattentive people throwing their car into reverse in a parking lot and I don't hear their ICE vehicle running at all.
    Kwerty, bisco, fuzzy1 and 1 other person like this.
  4. Kimberly19
    Kimberly19 Member
    105
    86
    Rhode Island
    This thread saved me some stress about this odd sound and a trip back to the dealer.
    Ovation, dtsexpert and bisco like this.
  5. Tomca
    Tomca Junior Member
    48
    CA
    Yeah, it reminds me of my original post of a annoying hissing sound.
    I also noticed that the sound is differnt from car to car. I ask the seller to drive 3 cars by passed me, and I chose the one with least annoying sound.
  6. MScelery
    MScelery Junior Member
    82
    24
    Mississippi
    So it can or can’t be lowered?
  7. Tomca
    Tomca Junior Member
    48
    CA
    I am pretty sure there are videos on how to do that. But it is illegal now I believe.
  8. bisco
    52,188
    it might be possible to lower the volume legally, i'm not sure. check the owners manual, and ask a dealer. you might need tech stream
  9. Salamander_King
    Salamander_King Senior Member
    11,020
    8,955
    New England
    As I stated above in a previous comment, it was owner customizable using Carista or Techstrem in pre-2020 models. In the 2021 owner's manual, this item for VPNS sound level does not appear on the customizable item list. I assumed that means it can no longer be changed, but I have not checked it with Carista on my 2021 PP. On my 2020 PP, the default was set at the highest, but still, it was barely audible.
  10. Ovation
    Ovation Active Member
    156
    130
    Quebec
    I believe the law requiring such sounds, at least in Canada, became effective in 2021, so it is no longer possible to alter its volume because of that. Same principle as the reverse camera requirement here—I think it was 2018 or 2019. As a result, a base model Nissan Micra came with a camera as standard equipment whereas some cars of much higher price/category still had it as an option a year or earlier.
  11. bisco
    52,188
    i can find u.s. implementation of sep 2020, and speeds tp 18.6mph, but i cannot find decibel requirement and measured where.
    wiki says 'the sounds must be loud enough for pedestrians to hear over backround noise'o_O
  12. bisco
    52,188
    see II B. federal government, no page numbers :cool:
  13. Trollbait
    12,633
    Likely what the law says.
  14. alexatie
    alexatie New Member
    Boston
    Anyone with a 2021 PP and Carista, can you please confirm if it's possible to lower the VPNS sound level or disable it?
    I rather do this this then to open the hood (i am not handy with cars).
  15. jerrymildred
    11,517
    14,157
    Tampa, FL
    Not on a 2021. Big gubmint says we aren't smart enough to make a good decision on that. Previous model years had three volume settings.
  16. MScelery
    82
    24
    Mississippi
    I saw a YouTube video, maybe posted here, where someone takes the actual speaker out and fills it up with something to soften the noise.
    Does that work?
    My Prius is way louder than my wife’s explorer, and frankly that’s stupid.
  17. jerrymildred
    11,517
    14,157
    Tampa, FL
    Others have reported that you need to replace the speaker with a resistor or the car will throw a code. Others have wrapped the speaker in bubble wrap. Others don't seem to mind.
    MTN likes this.
  18. MScelery
    82
    24
    Mississippi
    Thanks. Did bubble wrap actually help?
  19. jerrymildred
    11,517
    14,157
    Tampa, FL
    I think they said it did. I'd think it would.
    MScelery likes this.
  20. Salamander_King
    11,020
    8,955
    New England
    I have not tried Carista on my 2021 PP. I suspect they will not give me another free 30days trial. That means a paid subscription for the app, $9.99/mo or $19.99/3mo or $49.99/12mo. Since I don't really mind the sounds of VPNS nor the most hated Reverse beep, I really don't see the reason to spend the money. But as stated above, I don't think it is customizable anymore on 2021 PP.
