I have the problem of Prius 2010, you walk with me a gallon of 15 miles. What is the reason? I am ti
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Akrm alhafi, May 23, 2021.
  1. Akrm alhafi
    Akrm alhafi New Member
    Gmail
    I have the problem of Prius 2010, you walk with me a gallon of 25 miles. What is the reason? I am tired of consuming gasoline. What is the solution?
    52,331
    welcome!
    trade in for a gen 4. gen 3 (2010 being the oldest) has a massive egr clogging problem which will kill your mpg's, then blow your head gasket.
    how far did you have to walk for that gas, were you a long way from a station when you broke down?
  3. Grit
    Grit Senior Member
    6,575
    4,228
    Wilkes Land
    taxi, public transit, carpool, uber, lyft, bicycle.
    edthefox5 likes this.
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Where are you located? How many miles on your 2010? Do you dive in very hot or cold weather? Short trips? High speeds? Any other problems with your Prius?
