2010 Prius Intake EGR ports clogged runs rough from idle up to 65 mph
Discussion in 'Gen 3 Prius Technical Discussion' started by RobRig, May 24, 2021.
  1. RobRig
    RobRig Junior Member
    Richmond, VA
    My 2010 Prius began to run rough at slow speeds and on deceleration beginning a month or so ago. Roughness got progressively worse to the point of running rough at any speed below 65 mph.
    I removed the intake manifold and cleaned the crud out of the EGR passages and made a 15 minute video.
    I'd like to share a YouTube link with the group for others experiencing similar problems.
  2. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Wow. Lot of carbon. Have you done the cooler yet?
  3. PriusII&C
    PriusII&C Active Member
    426
    144
    San Jose, California
    Good job!:)
  4. ChapmanF
    18,317
    10mm socket for squeezing the wretched wire harness clips is worth the price of admission. Thanks!
  5. Mendel Leisk
    41,645
    Yeah he says “a couple of months back” he did the cooler, words to that effect. The intake is the last leg of the Exhaust Gas Recirculation circuit; until it’s cleaned the EGR cleaning is pretty much for naught.
    RobRig likes this.
  6. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    There have been several revisions to the Gen 3 intake manifold, I replaced mine with the current version when I did EGR cooler on my 2010 at 156K. Will follow your procedure next time, excellent video!
    RobRig and mikey_t like this.
