Engine ventilation modification
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ghost2255, May 26, 2021.
  1. ghost2255
    ghost2255 Junior Member
    Poland
    I'm curious what do you think about my idea for modification of engine ventilation system?
    I plan to connect PCV directly to hose between engine and intake(Z shape rubber hose on the top of the engine).
    It will eliminate vacuum in ventilation system and I hope oil consumption will bo gone.
    Am I right or this is stupid PCV mod.png and will not work?
    P.S Sorry for my bad english :)
  2. Mendel Leisk
    41,394
    I think you’ve effectively sealed the crankcase; rerouting the original exit flow to the entrance. In other words: not good.
    Jim Swart likes this.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    No new ideas are stupid, you’re on to something. I’m all for improving our outdated vehicles just like everyone here, hope your mod works out.
  4. bisco
    51,891
    do it!
    and let us know how it goes(y)
  5. ghost2255
    Poland
    The crankcase will be not sealed. Both in/out ways are open. Only The gas flow changes direction.
    This is my idea. I will do it and see what will happen. :)
  6. bisco
    51,891
    subscribed, all the best!
  7. Mendel Leisk
    41,394
    The out way feeds back into the in way? Effectively then there is no exit, my opinion.
    I think the net effect will be a dirty throttle body.
    mjoo likes this.
  8. ghost2255
    Poland
    pcv mod2.png This is corrected gas flow in my modification.
    Dirty throttle body...hmmm maybe. Will see.
  9. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Why do you think your oil consumption will be reduced?
  10. ChapmanF
    18,136
    I'm kind of wondering how well your mod will do at matching what the system is intended to do at different operating points.
  11. ghost2255
    Poland
    Like I wrote, I want to eliminate vaccum in ventilation.
    When you remove intake mainfold you'll see how much oil is there. I think this is because PCV valve sucking out oil from crankcase. Oil is only "after" inlet of PCV in IM, thats why I think my mod may reduce oil consumprion.
    Today I will do my mod and will observe few days what will happen.
    Maybe I'm wrong. But I want to see.
  12. ghost2255
    Poland
    Done.
    Time to test.
    Civiceg94, bisco, Grit and 1 other person like this.
  13. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    Any updates? I am interested in your findings
  14. AzusaPrius
    AzusaPrius Senior Member
    2,180
    919
    Almost a year of testing, how has this worked out for you?
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Yes, we are all curious. Hopefully some positive results.
  16. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    I'd rather have the crankcase be in a vacuum. Vacuum reduces aerodynamic drag on the crankshaft and rods which increases engine efficiency. If you're worried about drawing in oil, use a catch can.
  17. Abarnabe
    Abarnabe Active Member
    168
    100
    Netherlands
    it must have thrown an error, there is a sensor near to the pcv and if it doesen't sense what it expects, the engine light will pop up.
