Tire light will not turn off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chalie, Jun 2, 2021.
  1. Chalie
    Chalie Junior Member
    Hello all. I have a 2006 Prius. I just replaced all four tires and tire sensors. My tire light will not turn off. I’ve followed all the steps for resetting and nothing is working. I’ve read a lot of threads and links on this matter and nothing seems to help. Has anyone else ran into this problem and was able to fix?
  2. ttou68
    ttou68 Active Member
    351
    211
    You will need to program your newly replaced TPMS sensors to your vehicle's computer...
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    No resetting the new tpms because they were never installed.
    You must use techstream software to install the new tpms units ID into the cars software.
    Use the search forums link up top and search
    tpms. And techstream
    hoped you used the Denso units other cheaper units are troublesome,
    JohnPrius3005 likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Or pay a dealer or independent tire shop to do it for you.
    Call around for the best price.
    Chalie likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,034
    1,965
    NJ-USA
  6. Mendel Leisk
    41,295
    May be gone.
  7. fuzzy1
    10,399
    If a shop did the installation, then go back and have them program the new TPMS sensor ID codes into the car. This should have been included as part of the installation service.
    While other things can go bad, forgetting this programming step is somewhat common, and happened to me when having new tires and sensors installed on my other car just last month.
    Chalie likes this.
