  1. ASRDogman
    ASRDogman Senior Member
    7,745
    3,962
    I guess you have the metal oil filter housing, and not the original plastic one?
    Or did you get the metal housing?
    Or glue the magnet to the plastic housing?
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Today I finally crawled under my car and changed the oil. I also swapped the plastic filter cap for the aluminum one that Toyota put on the 1.3 they used in the Scion iQ. I test fit the cap both with and without a filter in the extra housing left over from my engine swap. It fits exactly like the plastic one. To get the o-ring for the metal plug in the end of the metal cap, you do have to get the iQ filter though.
    It is part number 15620-40030
    xliderider likes this.
  3. ChapmanF
    18,427
    Is there an advantage to the aluminum one over the plastic one? And what's the plug in the end for?
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    The plastic one I removed this oil change, that I put in to the specified torque minus 5%, split on me as it came loose.
    On the iQ, the filter hangs vertically, so the plug in the end is to drain it. The drain fitting comes with the filter.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    icyrius likes this.
  6. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Finally we have car shows again !!! (y)
    What a great time with the Socal Prius crew at Toyotafest 2021 yesterday.... already looking forward to next year :)
  7. amarino
    amarino Active Member
    142
    105
    99
    Hmm I wonder what is different between the 2011 and my 2015. Screenshot_20210606-122046.jpg Screenshot_20210606-122159.jpg
  8. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Installed an air compressor that will be hidden behind the rear bumper. The yellow object is a retractable extension cord connected to my inverter.
  9. Inza2
    Inza2 Member
    43
    106
    Netherlands
    Johnsk93, icyrius and Burna J like this.
  10. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    also had a 4500lbs winch installed, hidden behind the front bumper.
    you might notice I had to relocate the dynamic cruise radar to the lower grill, Some Abs plastic in front of it and it works as it did before!
  11. xliderider
    8,140
    3,277
    Honolulu, HI
  12. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
  13. ChapmanF
    18,427
    Neat! What is holding that compressor in place? Is there a structural version of Silly String?
  14. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    It's thermoplastic, long as it's not in direct sun or on metal in direct sun it'll hold up to pretty much anything.
  15. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    changed my engine water pump for the second time this week. The first time, I had less coolant than I thought at the house, had to drive to AutoZone, the one I called that was open wasn't the one I drove to. On the last stretch to the right Autozone with 2 minutes before they closed I hear the water pump grinding. Had to way 2 days for another one and now it's in working as expected. Now I need to figure out how to get that permanent code off my ECU.
    #18795 black_jmyntrn, Jun 16, 2021
    Putu Ariawan likes this.
  16. ChapmanF
    18,427
    That's a pretty generic term, covering about any resin that isn't thermoset. What did you end up using? Do you have any fasteners in there or is it just sticking on the sheet metal? Was the paint scuffed or prepared in any way for that?
  17. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    Permanent code will go away after 5 “drive cycles”. The exact definition escapes me right now though.
  18. FST4WHT
    FST4WHT Junior Member
    Sacramento, CA
    Yeah bolt right on. No spacers needed.
  19. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Wrapped car midnight purple recently and gilded/installed most of my emblems. 20210623_193746.jpg IMG_20210617_213235_909.jpg IMG_20210616_133418_065.jpg
    IG: twnzy_
  20. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    I used a few self taping screws and left space between the head and the body to wrap around to create an anchor. The air compressor I bought will be replaced with one that will allow me to use an air gun, when that happens I plan to use some thin metal wire as a skeleton then cover with material.
    It did! Thank you!
