Has anyone experimented with MPG when "trying" vs "not trying"
Discussion in 'Gen 2 Prius Fuel Economy' started by yossi, Jun 10, 2021.
  1. yossi
    yossi Junior Member
    61
    My new to me 2008 is getting around 45 in the city and this is with me constantly watching the screen, coasting, gliding, using cruise control etc. I am just curious if anyone has experimented with going an entire tank where you just drive and not worry about hard accelerations, coasting, etc and how much of a difference that made in MPG
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    If I drive my 2007 without a care in the world then I'm around 44-46 in the nice weather. If I pay more attention, using the same exact travel routes, currently 53+.
    Here's a picture I took this morning when I stopped to fill up.
  3. Tideland Prius
    16,615
    Yup. It's the difference between 55-60mpg vs. 47-50mpg when I had the Gen 2 back in the day.
  4. bisco
    52,386
    on my 08, i could go from 45 all the way to the low 60's under the right circumstances. (on the screen, not actual at the pump)
  5. Mendel Leisk
    41,898
    I don’t think I could do that. It’s not JUST for fuel economy; it tends to bleed into tailgating, lane jumping, speeding and flipping off “slow pokes”, rolling stops, and so on. Oh, and leaving it running with the AC while you run into 7-11, idling in drive-thru’s. Ugh…
  6. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    I haven't found too much difference between "driving like a saint" and a little less saint-like between identical trips on different days.
    Biggest variance I've seen to date has to do with how fast you cruise.
    Next bigger one is the outside temperature.
    srellim234 and Data Daedalus like this.
  7. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    If I really try on flat terrain at 45mph, with little traffic, I get 65-72mpg for a ten mile ride.
