  1. Blurredforlife
    Blurredforlife Junior Member
    71
    Chicago
    I installed new spark plugs before this happened...
  2. Blurredforlife
    71
    Chicago
    I love the car..I think its got a bad headgasket and maybe the rings have gone bad.
  3. Blurredforlife
    71
    Chicago
    Sadly I don't have space. I live downtown Chicago
  4. Blurredforlife
    71
    Chicago
    I think the rings are bad. I checked out the prior owners matinance records..she wasn't very proactive
  5. Blurredforlife
    71
    Chicago
    Said it was good. This has kinda been an on going problem I thought the stealership solved
  6. Blurredforlife
    71
    Chicago
    Update...So two weeks ago I started putting alittle seafoam in the case. Ive driven from Chicago to Cincinnati 3 times changed oil added alittle seafoam. It appears to have stopped burning oil.
  7. bisco
    48,943
    nice, all the best!(y)
    Blurredforlife likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    Here we go with SeaFoam again.
    It is a combination of 3 or 4 SOLVENTS that tends to break down oil.
    It is sometimes useful for cleaning/freeing stuck rings.
    But is should NOT be used in your oil on a routine basis......because it tends to dilute and break down the oil.
    The cure might end up being worse than the disease.
    :eek:
  9. Blurredforlife
    71
    Chicago
    Gonna replace the egr tank tomorrow..see what happens. Going to also do a leak down and a compression test as well. Appreciate the info
    Samuel Williams Jr and bisco like this.
  10. Blurredforlife
    71
    Chicago
    The Autoguys in Milwaukee cleaned my egr..said it was one of the dirtiest they have seen. Also told me to switch to 5w20 oil with my burning problem.
  11. Mendel Leisk
    38,205
    Tricky to get good pics of the interior, get's thrown off by the bright flange, you have to override exposure. With a phone tap on what you want exposed correctly, or just move the exposure slider.
    Good you got it done. Intake too?
    I don't think thicker oil is going to do much. A $2k short block yes, lol.
    #51 Mendel Leisk, Jun 29, 2021
  12. Grit
    Grit Senior Member
    6,109
    4,038
    Wilkes Land
    if not, next post by op will be “smoked twice.”
  13. Blurredforlife
    71
    Chicago
    Yes..they cleaned the whole egr and intake manifold
  14. Blurredforlife
    71
    Chicago
    Lol damn
