Help...Prius spare tire setup question/problem
Discussion in 'Gen 4 Prius Main Forum' started by CyndieW, Jun 12, 2021.
  1. CyndieW
    CyndieW New Member
    Flower Mound, TX
    2018 Prius
    Hi All,
    I just got a 2018 Prius Four. I am doing the replace the tire repair kit with a real spare tire setup; I removed the old foam, and I found thick sticky tape all over the wheel well - I guess that is OK -- I just remove it around the screw down; BUT, when I put the donut wheel in the well and tried the screw it down, the screw was NOT LONG enough; the replacement foam fit fine over the tire. What do I need to do? What did I do wrong? (see photos).. The screw down I got is 51931-47010.
    Please Advise
    Thanks
    Cyndie
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    How long is your screw down? Mine (2016 Prius 3) has about 1.5 inches of threads below the plastic.
    JeffD
  3. CyndieW
    CyndieW New Member
    Flower Mound, TX
    2018 Prius
    Hi JeffD,
    see photo of screw -- with ruler
  4. CyndieW
    CyndieW New Member
    Flower Mound, TX
    2018 Prius
    hmm -- did some Googling -- and found part 51931-47030 -- I'm going to give that a try.
  5. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Looks about the same as mine.
    JeffD
  6. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Is it possible the spare needs to be flipped over? Just saying that might be the case but unsure
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    I can't recall ever seeing "dynomat" sound deadening material applied by the factory. You may need to remove that stuff from the bottom of the tire well to have the spare sit in there correctly.
  8. Gokhan
    Gokhan Senior Member
    6,529
    2,608
    Paramount CA
    #8 Gokhan, Mar 13, 2023
    CT415 likes this.
