  1. Boatracer1000
    Boatracer1000 New Member
    Hi everyone,
    The other day I noticed my daily 05 Prius making a new noise. The car is now very loud, it’s almost like I’m driving on off road tires, & as I slow down there is a different sound. Hard to describe but it has a rhythm to it. There are no dash lights, no trouble codes, no noticeable vibrations, shakes, or shimmies. I have 340k miles, I also have Ecopia tires with even wear & 30k miles on them. Thanks everyone in advance
  2. JC91006
    JC91006 Senior Member
    16,470
    8,383
    You should check the tires and see if you have a nail/big nail stuck on the thread
  3. Boatracer1000
    It’s not that type of a sound, it’s more constant
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Sure your cat was not stolen?
  5. Boatracer1000
    Not a cat sound, I just replaced the whole exhaust
    edthefox5 likes this.
  6. PriusCamper
    PriusCamper Senior Member
    10,927
    4,430
    Pacific Northwest, USA
    Need more details... what corner of the car is the noise coming from? Or is it engine/transmission. Have someone else drive while you crawl around inside and try to isolate the source of the sound.
  7. Boatracer1000
    It doesn’t sound engine or trans to me. I’m calling the shop that worked on my car last & ask what pattern they used to rotate my tires & I am going to try unrotating them.
  8. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Cool.
    Were you able to sell your cat? Its worth $1500+.
    Take the back hatch out where the spare tire lives may have something loose in there rolling around. While your in there grab a flashlight and look closely in the 12 volt battery hole see if its full of water. The G2's have alot of leaks that's the #1 leak spot.
  9. Boatracer1000
    I still have it sitting in my garage, just haven’t had time to shop prices.
    It’s not that type of sound
    Oh yeah the 12v battery area is pretty much rotted through, I’m going to work on patching the area at some point
    #9 Boatracer1000, Jun 13, 2021
