after market Fog/Driving Lights Install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Hammared87, May 2, 2021.
  1. Hammared87
    Hammared87 New Member
    St. Augustine FL
    Please see Pictures>>> I bought some driving lights that came with the corner grills with an opening for the lights, light, and bulb as well as harness and switch.
    It did not come with either the Instructions and not sure how the actual lights fit the grill?
    Does anyone have any pics of lights mounted in the grill so I can see if there's another part that needs to be purchased, a part that will hold the light into the grills ?
    Switch was a direct fit into the dash plug, and looks great, however the lights fit into the opening but may require a bracket or something ?
    They float around when I test fit them into the grill opening.
    Thanks
  2. Hammared87
    St. Augustine FL
    Actually, I pulled off the factory grill and saw there is a mount for this light. Problem solved
  3. ColoradoCrow
    ColoradoCrow Active Member
    931
    381
    Leawood, KS
    I
    I need to do this for my wife’s Prius. How did the install go? What is the electrical connections you made. Can you post install instruction pictures? How bright are they? Are the bulbs glass or plastic? Where did you buy them? Do you have a link?
    TIA.
