HV fan wiring
Discussion in 'Gen 3 Prius Technical Discussion' started by smokeGTI, Jun 14, 2021.
  1. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Hi all,
    I have a Prolong charger for my Gen 2, now my Gen 3 starts getting HV battery problem.
    So I was trying to use Prolong to charge it as well.
    But I found the HV fan of Gen 3 is quite different form gen 2.
    Can't get the fan to spin with the charger.
    Does anyone have experience on this ?
    Or anyone who know how to trigger the HV fan on the bench test ?
    TIA.
    52,277
    if no luck, ask prolong
  3. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Yes I have sent them email today. Hope they won't tell me to buy a new charger for Gen 3 instead. :)
  4. bisco
    52,277
    me too!
    i suspect it is a harness issue,but not sure
  5. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    You need to buy the harness for the Gen3.
    According to there site, best I understand it, the charger/discharger is the same.
  6. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
  7. PriusII&C
    PriusII&C Active Member
    426
    145
    San Jose, California
  8. PriusCamper
    PriusCamper Senior Member
    12,982
    5,278
    Pacific Northwest, USA
    I was able to get fan control boxes from them for $15, but that was semi-warranty related and it took them months to follow through. It might be easier to adapt your Gen2 fan to work in place of the Gen3 fan...
  9. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "How did you control the fan speed?"
    Pretty sure you don't have to; when engaged, the Prolong system runs the HV fan at full speed.
  10. PriusCamper
    12,982
    5,278
    Gen3 might be different, but gen 2 prolong harness runs the fan by gradually increasing voltage from 0v up to 6.5v and while you can hook the fan up and run it at 12v, the fan runs faster than it would normally with that much voltage and could over time cause damage. To determine if that damage is a real risk, we need to better understand why Toyota has a 12v fan they're only sending max 6.5 volts to?
  11. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    dr prius app shows up to 8 volts on blade voltage.
  12. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Yes exactly, but no way to control the fan speed.Probably no need to.
    I have wired an on/ off switch between GND0 and S10, sorted the problem temporary.
    #12 smokeGTI, Jun 14, 2021
  13. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    I've just added a $3 cheap motor control, now I can manually control the fan from stop to full speed.
    #13 smokeGTI, Jun 15, 2021
  14. bisco
    52,277
  15. Melthias
    Melthias Member
    100
    36
    Southern Maine
    I am in a similar situation to the OP, I have a charger and harness for my Gen 2, and would like to use the same charger on the Gen 3. This charger is from Hybrid Revolt and they do not have a harness for the Gen 3. However, I am thinking about buying another Gen 2 harness and wiring their fan control board to run the Gen 3 fan. Their board is wired into the Green, Yellow, and Black/white wires to the Gen 2 fan. So I am thinking that I would hook up the board to IG0, SI0, and GND0 respectively. I am not sure what the colors are in the Gen 3, but I think I can figure it out.
