Using BG EPR/MOA/44K kit when not changing your own oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusPaddler, Jun 15, 2021.
  1. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    My Prius is 2009, 235k or so, sometimes burns a bit of oil between changes but not enough that I ever need to add it. MPG has gone down to mid-high 30s. Is a bit rough switching between engines or to idle at a stop. Nothing too bad, but hoping to help keep her healthy.
    Decided to try the BG kit, but I do not change my own oil. I have read here and watched videos about how to put car in maintenance mode, add the EPR and then run for 15-20 minutes. Then it always says you should IMMEDIATELY change the oil.
    QUESTION 1 - can I do this myself outside the garage that will change the oil and then let car sit until its my turn for the oil change? Will have to drive a few feet after the treatment to get into the garage. Would sitting for an hour (if they are backed up) or more hurt it?
    Then, I think after draining the oil + detergent, you add the MOA intermittently with the new oil (a little oil, a little MOA, a little oil, a little MOA)...
    QUESTION 2 - can I add this all at once after the shop puts in the new oil?
    Thanks in advance.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,513
    Bay Area, California
    2019 Prius Prime
    I've done the EPR treatment outside the dealer before. It was fine;).
    I add the MOA about a quart into the new oil add. But maybe ask the shop to add to the midpoint on the dipstick so it can be added later :).
    Good luck and keep us posted(y).
    PriusPaddler likes this.
  3. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    Done!! I poured in the EPR and ran the car before the oil change. They wouldn't let me add the MOA mid-fill, but I did add it immediately afterwards. Then I put in the 44K and filled the tank.
    I ran errands for 20-25 miles afterwards and it REALLY seems to have helped. Time will tell, but in that 20+ miles on stop-light roads, there was only one brief "shudder" when switching between engines - lasting maybe about 1/4 of the time it used to take, and mostly the switch was SEAMLESS. Could it really have made that much difference? If so, well worth it.
    Next week - PCV valve and maybe new plugs. My car is gonna have a new lease on life!!
    mikey_t and Raytheeagle like this.
  4. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    Glad it worked out for you :).
    I have started our 2019 Prime at 30k miles to BG Products treatments;).
    Should be a help(y).
    mikey_t and PriusPaddler like this.
  5. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    Thank you! I will be putting the kit on my Christmas list, lol.
    Raytheeagle likes this.
