Earth trapping heat
Discussion in 'Environmental Discussion' started by bwilson4web, Jun 17, 2021.
  1. bwilson4web
    16,127
    Source: NASA: Earth is trapping 'unprecedented' amount of heat, warming 'faster than expected'
    Since 2005, the amount of heat trapped by the Earth has roughly doubled, according to a new study by NASA and National Oceanic and Atmospheric Administration researchers.
    This is contributing to warming oceans, air, and land, the scientists write in the study, published this week in the journal Geophysical Research Letters. "The magnitude of the increase is unprecedented," NASA scientist and lead author of the study Norman Loeb told The Washington Post. "The Earth is warming faster than expected."
    Using satellite data, the researchers measured the planet's energy imbalance, which is the difference between how much energy the planet absorbs from the sun and how much is radiated back into space. If there is a positive imbalance, the Earth is absorbing more heat than it is losing; in 2005, there was a positive imbalance of about half a watt per square meter of energy from the sun, and in 2019, the positive imbalance was one watt per square meter, the Post reports.
    Expected, this is bad.
  2. Merkey
    Merkey Active Member
    309
    279
    Birmingham, Michigan
    Do we need to go nuclear, and quickly?
  3. Zythryn
    Zythryn Senior Member
    6,408
    4,406
    That would help, but won’t solve the issue alone.
    There is no ‘sliver bullet’.
    However, there are a number of partial solutions that will easily add up to tackle the issue.
    bwilson4web likes this.
  4. bisco
    51,564
    i would like to trap some for this winter :cool:
  5. privilege
    privilege Active Member
    659
    169
    Birmingham
    sooooooo, stop using energy all together and look for shade ?
    I predict 0% of people will do this
  6. Zythryn
    6,408
    4,406
    At first I’d say this is a straw man fallacy, however it is so far out there I think the better classification is a non-sequitur.
  7. bwilson4web
    16,127
  8. Rmay635703
    Rmay635703 Senior Member
    2,661
    1,682
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’m pretty close to zero energy use in so far as my gas and electric bill is concerned
    Lots of people won’t give up a 4000sqft home cooled to 65 and heated to 80 with precision manicured / chemically treated climate destroying ground cover and have Luke warm sub 5 minute showers to get anywhere near that though.
    privilege likes this.
  9. bwilson4web
    16,127
    Obviously not married ... <GRINS>
  10. privilege
    659
    169
    Birmingham
    nice opinion. but do you have one for the topic of this thread ?
  11. privilege
    659
    169
    Birmingham
    humans like nice things, I'll agree about that. I really like heated interiors in the winter and cooled in the summer myself.
    given I probably have somewhere between 0-5,500 data left, I'm going to continue to enjoy things like eating meat daily and a comfortable home. I can't knock anyone else for doing the same.
  12. fuzzy1
    10,337
    If you mean Net Zero energy use, a number of us PruisChat members have already achieved that with our homes, producing enough net-metered solar energy on our rooftops or in community solar project shares to power the entire home. And do so without changing thermostat setting or turning down shower temperatures or other sacrifices. No fossil energy needed.
    I haven't (yet) extended this to my personal transportation, but a smaller number of folks already have done so, with their own solar energy powering plug-in vehicles.
    There are several more steps to getting one's supply chain weaned off fossil fuels, but these are good starts.
    #12 fuzzy1, Jun 18, 2021
    iplug, privilege and Zythryn like this.
  13. privilege
    659
    169
    Birmingham
    way cool!
    . we're bathing in energy waste here in our home. trees block the sun, and geothermal won't work (rock), so we're tied to the grid until we don't like being comfortable.
  14. fuzzy1
    10,337
    We suffer substantial shading from neighbor's trees, and from a rotten winter climate that serves up a painful number of 100% overcast cloudcover days.
    But we did it anyway. Those impairments just meant that I had to put up some more panels than people who live in solar-friendly locations.
    Some well drillers know how to bore through rock. Though that is usually for ground source heat pumps, which are for energy efficiency, not energy production, and air source is commonly cheaper.
    We're tied to the grid too, because our energy production isn't at the same time as our energy consumption. So we need either humongous storage batteries, or to use grid-tied net metering as a giant battery. The later is vastly cheaper and more resource efficient.
    It also nice to be on a carbon neutral grid. Not many utilities (in the U.S. at least) have achieved that. But the solar (or other home renewable source) net metering just as useful -- or even more so -- on the many other utilities that are not carbon neutral.
  15. tochatihu
    tochatihu Senior Member
    9,665
    3,728
    Kunming Yunnan China
    2001 Prius
    Publication behind this discussion:
    https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2021GL093047
    (free if you want it)
    Here is their 'money shot'
    The change in outgoing long-wave radiation strongly resembles marine heat uptake according to TOGA float fleet. 90% of newly thusly trapped heat goes into oceans (consistent with many other ways to understand this situation).
    Total increase is 0.5 watts/m2/decade, leaving 0.05 watts/m2/decade to warm troposphere by 0.18 deg C per decade. Aha! a Bob-Wilson steam tables problem may present itself.
    One m2 of average troposphere contains about 370 grams of water, almost all in gaseous (vapor) phase. Even in puffy white unto gray clouds, only a tenth of water is liquid droplets that backscatter and absorb light. This, among many other things, we shall ignore here.
    Narrow question posed is whether +0.05 watts increases temperature of 370 grams of water vapor by 0.18 deg C? It happened over 10 years (3.16*10^8 seconds), but that cancels out.
    I suppose that the other (nitrogen oxygen argon) gaseous heat capacities must be considered, but water has 3 atoms which gives it several more ways to jiggle. Yes, that is middle-school terminology, but the next step up involves techno-words that readers may not even want to hear. Let us ask first what the steam tables show.
  16. tochatihu
    9,665
    3,728
    2001 Prius
    OT, but no more so than most responses here :) Those which I also very much enjoy.
    Five to 10 years ago I wondered about Mars. Its atmosphere is thin, but it has as much CO2 'in the stack' as Earth's. Much less 'greenhouse' warming happens there, per solar watt. Why ain't it working?
    Mar's atmosphere is 95% CO2. Every CO2 molecule sees the same solar heating (jiggle making), but can only transfer kinetic energy to other CO2 getting the same. So net energy transfers are zero. In contrast, Earth's atmosphere is mostly nitrogen, which 'can't see' solar watts, but it totally feels the bump from (rare but kinetic) CO2.
    This was my aha moment. The always-called-on greenhouse effect is completely context dependent. When James Webb Telescope goes up and looks at planetary atmospheres many light years distant, it might have enough spectroscopy powers to discern if CO2 is a minority gas. Only for some planets can CO2 modify perceived habitable zones and this depends on CO2 being a minority gas.
  17. bwilson4web
    16,127
    Hummm, I had not considered this mechanism. Rather I was happy enough with the 're-radiate' close to a surface.
    Upon absorbing a photon of light at the appropriate wavelength, the CO{2} would re-radiate that photon in a random, direction. Since the earth is the nearest large object, just under 50% of all directions, the re-radiated photons had a high probability to going earthward and increase the effective solar flux.
    Regardless of mechanism, here is an article showing the kinetic transfer versus re-radiate:
    Carbon Dioxide Absorbs and Re-emits Infrared Radiation | UCAR Center for Science Education
  18. Mendel Leisk
    41,013
    Yeah what’s going on; getting a little toasty on the weekend…
  19. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
  20. Mendel Leisk
    41,013
    #20 Mendel Leisk, Jun 28, 2021
    Steph1972 and bwilson4web like this.
