Coolant valve question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robert Kwasny, Jun 19, 2021.
  1. robert Kwasny
    robert Kwasny Junior Member
    35
    so cal
    Been having problems with rough engine idle and rattling sound at cold start. Already cleaned the throttle body replaced the plugs and even cleaned the fuel injectors although I'm not sure that I did that effectively. Now when driving under light loads I'm hearing this low pitched purring sound. I have had Coolant control valve codes for quite some time now but just ignored it thinking it's not related to engine performance. Then I ran across this article attached. Any chance this could be my problem?
    52,286
    are you losing any coolant?
  3. JC91006
    JC91006 Senior Member
    16,815
    8,596
    Your car needs a good tune up. Check plugs, coils, injectors. rough idle isn't really a coolant valve symptom
  4. robert Kwasny
    35
    so cal
    not loosing fluid.
  5. robert Kwasny
    35
    so cal
    so disregard that article.
  6. JC91006
    16,815
    8,596
    If you have a check engine light on (or any warning light on), you would need to read the engine codes. No article can help in guessing what the problem can be
  7. bisco
    52,286
    how many miles on her?
  8. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Have you checked, or cleaned up the VVT filter?
  9. robert Kwasny
    35
    so cal
    I have read codes p1121
    114,000
    what is a vvt filter?
  10. JC91006
    16,815
    8,596
    114k miles shouldn't really display any bad symptoms. Are your plug replacements with Denso or NGK branded plugs? P1121 is actually a warranty item in CA, it's covered by the emissions warranty 15 years or 150k miles, whichever comes first. Since you have a 2005, the warranty has ended for this but it would have been in effect if you had this issue before the 15 years was up.
    I would replace the engine coolant valve first and get rid of the check engine light. If you're looking to maybe sell your car, I would be interested in buying it. Please email me at [email protected]
  11. robert Kwasny
    35
    so cal
    Thanks it's my daughter's car I'm trying to undo what shoddy mechanics did to it for the last 10 years and then there's the stolen catalytic converter and the HV battery failure.
