I just bought a CPO Prius V. Lots of issues.
Discussion in 'Prius v Main Forum' started by gromittoo, Jun 15, 2021.
  1. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    I wish I had known that I could block the user, or I would have done it after "her" first post. I did find a way to "report a user", but that does nothing.
    I do want to do something before I close this Chapter. In one post, I mention the full name of the Toyota Dealer. I can no longer edit that post. Given all the negative things "she" said, some web crawling search engine may pick up this thread, and associate those negative things with that dealership. And those negative things were based on an overreaching jump to conclusions, and not actually representative of that Dealership.
    Yes a few things went wrong with this transaction, but ultimately the dealer made good. Things worked out as I suspected they might. In the end, I am satisfied, and will rate the dealer well when I get the chance.
    If there is a way for a moderator to remove the name of the dealer, it would help me close with a sense of fairness.
    Air_Boss likes this.
  2. Mendel Leisk
    41,808
    Click on avatar picture (or tap on phone): there's a pop-up with their avatar, and several options, including "ignore". Screen grab on pc, phone would be similar:
    "Report" is useful for a lot of things, from benign stuff like they're green and posted in wrong forum, to they're posting the same question in multiple threads, and yeah abusive/trollish behaviour.
  3. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    Thanks for the Info, Mendel.
    Any possibility that I (or some moderator) can edit my post to remove the dealer's name? Apparently the "edit" feature goes away at some point. I suspect once someone replies to it.
    I guess I am naive old man. Reddit forums about Rideshare, or anything political, I expect trolls. My vast experience with automotive type forums and PriusChat in particular, and this is the first time I have encountered a troll.
    In Hindsight: The 800 number for the Toyota CPO program would have been the most valuable thing I could have had shortly after this thread was started. I could have googled it, but I was so flustered, it did not occur to me that is what I needed. Hindsight in my case is far from 20/20 (recovering from Cataract surgery) :)
  4. Mendel Leisk
    41,808
    Report (button below every post) the posting, explain what you’d like done. As long as it’s sensible, I’m sure they (mostly he) will do it.
  5. PTS
    PTS Member
    91
    Austin, Texas
    2013 Prius v wagon
    If the shoe fits
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,496
    2,470
    Taylors, SC
    You wear heels, too?
  7. icyrius
    icyrius Active Member
    240
    114
    Florida, USA
    2014 Prius v wagon
    I would buy this wagon tomorrow if available
  8. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Gotta love the robotic translation to English.
