Tailgate Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by GabrielD, Jun 25, 2021.
  1. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Recently I discovered a buzzer in the right side of tailgate, near signal lamp.
    Does anybody know what is the purpose of this, and where is connected?
    I can't find any wires around.
    I already have a buzzer and beeps when I go reverse...
  2. Mendel Leisk
    41,778
    Someone owned the car before you? Previous owner installed?
  3. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Yes, it was a pre owner, but I am willing to put order in this and try to find connections.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    as if the stock back up beep wasn’t enough.
  5. Mendel Leisk
    41,778
    Could be a hatch-open warning? You'd need to follow the wires. If it's previous owner installed, I'd be very dubious it's needed. Do follow the wires back, see where they connect and that they don't compromise the stock wiring.
  6. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    The wires don't exist further than it's in the picture, only speaker with it's wire.
    But, after checking the wiring manual, could be this one?
    Theft warning siren assembly
      File size:
      169.5 KB
      File size:
      123.2 KB
  7. bisco
    52,220
    does it buzz when you put it in reverse?
  8. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Yes it does, I already mentioned it.
  9. ChapmanF
    18,412
    From the mention in post #1, it wasn't clear to me you were saying this thing buzzes in reverse. I thought you were saying the car already beeps in reverse.
  10. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    In the first post I wrote this:
    "I already have a buzzer and beeps when I go reverse..."
    I was trying to say that there is another buzzer in car and beeps when in reverse.
    Sorry for misunderstanding.
  11. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    so you have 2 buzzers and the stock beep in the car. Previous owner had ocd when it comes to back up audibles.
  12. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Nobody with Prius V, or Prius Plus to check if they have this extra buzzer?
  13. ChapmanF
    18,412
    It looks decidedly aftermarket to me. And if it isn't plugged in to anything, we have no way to know whether the previous owner wanted it for backup beeping or for some other purpose.
  14. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Ok.
    Thank you all for quick answers.
  15. hoffeck
    hoffeck Member
    Germany
    Do you have park distance control sensors in the rear bumper?
    I have this and also a separate speaker in the rear.
  16. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    No, no sensors, only camera.
    Maybe this is the purpose for that speaker, thank you.
    In case you have access to that area (near rear right signal) please, make a picture.
  17. bisco
    52,220
    some people complain that the prius reverse beep cannot be heard behind the car, so the previous owner may have wanted a warning back there
    ASRDogman likes this.
