Rustproofing the suspension
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Apr 10, 2015.
  1. mypriuscious
    mypriuscious Member
    223
    71
    Cincinnati, Ohio
    @Mendel Leisk Did you switch to Linseed Oil as another post would suggest?
  2. Mendel Leisk
    41,633
    Yeah I did. Just revisited it, did the rear about a week back, and the front the day before yesterday. It was the second time, I'm losing track but close to 1.5~2 year since last application. I knew it was likely not needed, and the first application was holding up good, but I like to "do two coats".
    Boiled linseed btw.
  3. 04priusnow
    04priusnow Active Member
    345
    201
    I have rust on my driver's ide door bottom of the door where the seam and drain holes are. Thoughts on treating this without grinding it off?
  4. 04priusnow
    345
    201
  5. Mendel Leisk
    41,633
    South Main Auto’s done a two part on rusted suspension, 3rd Gen Prius:
    Paul E. Highway likes this.
