Consumer Rpt blesses Harbor Freight generator?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jul 14, 2019.
  1. Trollbait
    12,501
    "Storing a fully loaded torque wrench can result in a set in the spring, weakening the spring over time. But if you completely offload the spring to the zero setting, other components within the wrench may move a little. And in the world of torque, a little is a lot. Reapplying spring compression will shift orientation of these components, affecting accuracy."
    Guess it is best to read the manual.
    Stevewoods and Mendel Leisk like this.
  2. Mendel Leisk
    41,295
    For years I spun mine right down. They all seem pretty close in funky tests, so I guess no harm lol.
    Stevewoods likes this.
  3. cyberpriusII
    1,155
    1,762
    Mars Hotel
    Since this has strayed, I would personaaly appreciate a good, bad and ugly Harbor Freight tool thread. But, I am too lazy to start it.:p:D:D:cool:
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    SFO likes this.
  5. Stevewoods
    Stevewoods Senior Member
    659
    1,124
    Seattle, WA
    I still have not pulled the trigger and purchased a new generator....and now I have new requirements.
    Has to have "electric start option." While I can pull a start cord, wifey cannot.
    Has to be inverter. Has to be 3000 watts or better and "portable."
    I know Honda is king. But the king demands much gold.
    I still see good reviews on Harbor freight. But if anyone has a suggestion on other brands. I really think Honda is way overpriced. Harbor Freight is about where I want to be, but....
  6. Rmay635703
    Rmay635703 Senior Member
    2,667
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    There are a variety of inverters on the market, (but not tons)
    not just HF or Honda
    Stop in a Menards or HD and look at the others.
    The primary problem I have found is that the other brands are nearly impossible to start in colder weather even with electronic start, mainly coinciding with California emissions deleting the manual choke
    The other brands tend to not idle very smoothly and are a tad louder as well though I have had no other issues with our 2kw unit (and 2kw is the limit, it won’t even attempt to start a small AC unit even though continuous is well within the spec)
    Good Luck
  7. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I have a pair of the 3000/3500 watt Harbor Freight Predator inverter gen sets. They have both worked well. The longest outage was 4 days and we had continuous power the whole time.
    I use them to power the whole house via a transfer switch... except the AC. :( The AC was wired directly to the distribution panel built into the meter and my transfer switch is between that panel and the main panel inside the garage.
    One of the generators is enough to run the house, including central heating. That's how we normally run it. The generators can stack (run in parallel) to give 6kW of power. That's what we do when it's time to add fuel. We start the second one, and when the first is cool we add gas. When the second one starts to run low we again start the idle generator and turn off the one that's hot so it can cool down.
    We also run both gens in parallel when we want to use the oven.
    To run the whole house (split phase 220v) I have installed a step up transformer that converts the 110V to split 110/220. :) Without that transformer the transfer switch can only power the circuits that are on one leg or the other.
    Dan
  8. AzusaPrius
    AzusaPrius Senior Member
    2,170
    915
    tochatihu likes this.
  9. Leadfoot J. McCoalroller
    8,067
    7,548
    Pennsylvania
    2018 Prius c
    That sounds great- any details on the one you used?
  10. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    My CARB-compliant eu2000i has a manual choke. Is that a really new requirement? I bought mine in 2017.
  11. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I used this one. Holy Crap. I thought I bought a 10KVA model. I see now that it's only 5kva That makes it suitable for handling the output of one of the generators at full load, but not both at full load. I bought it from a guy who was an electrical contractor for a project. They ordered 5 of these and needed 4. The return shipping and restocking fee combined was high enough that they just decided to chuck them.
    The magic is to find a transformer that allows an input of 120 and a center tapped 220v. That gives you 110V to neutral for leg 1 and 110V to neutral for leg 2 that is 180 degrees out of phase. Leg to leg is 220v . The nomenclature of "secondary 120/240" on this label should mean that it's split phase.
  12. Stevewoods
    659
    1,124
    Seattle, WA
    Yeah, the turn the prius into a generator has been kicked around for years.
    The problem is, what if the Prius is not at the house.....which is likely in this case.....
  13. ETC(SS)
    7,131
    The other problem is price.
    You can buy a brand new HF genset every time there's a prolonged power outage for what the Prius setup costs.....well.....unless you live someplace like Baghdad where there they have rolling blackouts and brownouts regularly.
  14. privilege
    privilege Active Member
    659
    169
    Birmingham
    take a peak at the Honda and wen generators. Google "Honda clone". you'll find a ton are exact copies.
    the people I know that have copies love them
  15. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Personally, I'd like to trade my 3.5 kw predators for one of the new 9kw inverter gensets from Harbor Freight. It's much more expensive, but it will do a split phase 240 without needing the external transformer. The 9kW unit is also bigger and heavier.
    My wife was able to handle the smaller ones when I was out of town. She added fuel as needed and started / stopped them using the electric start.
    While many of the generators LOOK the same, you should take that with a grain of salt. It's easy to build a plastic shroud that looks like the competition, but it's the internal components that count.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I bought this one a few years ago right after Irma. I recommend it. Lots of youtubes about this model too. It runs very smooth and has good consistent output on propane. Electric start.
    Its a dual fuel I guess there all DF now. I have an auto switchover propane tank valve with gauges. I got gas backup too.
    But as Dan said there all Chinese junk unless you buy like a Honda which is very pricey. I know a few people who have Honda's I guess there very quiet.
    I have another older bigger generator that I use as backup that does not run half as smooth as this one but is ok. So I have 2 generators. Not going through what i went through with Irma. Out of power for 9 days. The other side of the street came back on 2 days before our side did.
    Rental house down the street on my side never trimmed there oaks back lost some big branches and took our drop down.
    I also have a low start up current window shaker. Its a 5000 btu with a 7 amp compressor turn on and 2.5 amp run.
  17. Stevewoods
    659
    1,124
    Seattle, WA
    Sorry, had not come back to this thread for a bit....
    edthefox5: What generator are you talking about? I assume there is something about my web browser that prevents me seeing something you pasted into your post.
    Basically, I ended up NOT BUYING anything as wifey said she was not going to try to move a 100-pound chunk of steel out of the garage if there was a power outage. But, I still need to get something. At the moment...well....I won't say what I am thinking, since that might anger wifey. :p
  18. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Go on Amazon search
    champion generator 76553
    it’s not heavy to move it has a metal lever you lift it and it rolls nice.
