Fishing a cable for dashcam
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AsifK, Jun 30, 2021.
  1. AsifK
    AsifK New Member
    London
    I recently bought a dashcam. I need to power from 12V / Aux outlet which is in centre box.
    I was wondering if you can refer me to any video which can show me disassembly to fish the wire.
    I have attached some images. I want to follow red route for wire hence want to remove these panels and put the wire in glove box. I am unable to find any videos on youtube.
    Any help will be appreciated.
      File size:
      37.2 KB
      File size:
      46.1 KB
      File size:
      32 KB
  2. KeinoDoggy
    KeinoDoggy Member
    I did not use the power outlet under the console lid. I used the outlet in the console tray. just ran the wire for mine to the outside left of the console>under bottom dash>above steering column>under driver side kick panel>driverside door gasket>headliner where it meets windshield. Easy
  3. StarCaller
    StarCaller Senior Member
    1,278
    730
    Cedar Crest, NM, USA
    I went directly from the under-dash fuse box with one of those:
    #3 StarCaller, Jul 1, 2021
