Does anyone know the part# for backlit Door Lock Switch?
Discussion in 'Prime Accessories and Modifications' started by robAlatte, Jun 1, 2021.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    OK, that confirmed that only 2019 and 2020 models are with LED-lit switches. Again, I never noticed that I did not have LED on my 2017 PP Premium nor did I notice that the switches were lit on my 2020 PP LE. That kinda tells me the feature is not necessary for me. I can live with either lit or unlit switches.
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I suppose it comes down to how often you need to operate them in the dark. It's not terribly often for me, but it's enough that I can recall my frustration at not being able to find the lock/unlock button easily more than once. I can feel my way around the four window switches, but having them lit is a nice touch.
    Salamander_King likes this.
  3. Salamander_King
    11,024
    8,972
    New England
    I didn't drive at night much, but I have driven enough times early in the morning before dawn, or return home after dusk. In either situation, I have never needed to unlock the door from inside when I parked the car. I just checked the manual and I am sure my door locking was set to the default setting, shift position linked for both locking and unlocking. So, it was unlocked automatically when the car was parked.
    PiPLosAngeles likes this.
  4. PiPLosAngeles
    1,551
    724
    My problem was always when dropping people off and they couldn't open the rear door. Then I'd reach for the lock button and end up locking/unlocking/locking/unlocking until we figured out which was happening and they could open the door.
    Sommer86 and Salamander_King like this.
  5. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    THANK YOU SO MUCH FOR TAKING THE TIME TO DO THIS!! Totally confirms a correct working part. Im going to order the same!
    Hopefully you got your clip out from the door.
  6. PiPLosAngeles
    1,551
    724
    Got it out no problem. Just pulled out the two snaps on the bottom and it fell out.
    robAlatte likes this.
  7. Dan Colasanti
    Dan Colasanti New Member
    Liverpool, NY
    My Dealer quoted me $500 today... found a used one on eBay for $54.
  8. Sommer86
    Sommer86 Junior Member
    Burbank
    Do you guys think the 2016 Prius door switch panel would fit on a 22? I remember the whole thing lit up and it’s had pictures of windows on it (with an “A” for automatic), not just the lines. Plus, I can get it off of my old wrecked car.
