Should I be concerned about this tire?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ElecTomato, Jun 20, 2021.
Tags:
  1. ElecTomato
    ElecTomato Junior Member
    Maryland
    What does the egr circuit have to do with getting new tires?
  2. ASRDogman
    ASRDogman Senior Member
    5,909
    3,167
    It will keep the tires from moving, because the cooler will clog and create back pressure
    and blow the head gasket.
    It's NOT as hard of a task as many make it out to be. Just a little time consuming the first
    time you do it.
  3. ElecTomato
    Maryland
    I'm not understanding the connections between tire changes and the egr coolant clogging and causing the head gasket to blow. What exactly will keep the tires from moving? Or, why will the coolant clog the valve? Does it have to new with new coolant added by the mechanic? Is this a routine cleaning that is to be done when tires are changed?
    #23 ElecTomato, Jun 28, 2021
  4. Mendel Leisk
    38,260
    There's no (non-humorous) connection to the EGR (Exhaust Gas Recirculation). Anyway, more info:
    Bad Flywheel | PriusChat
    ElecTomato likes this.
  5. ASRDogman
    5,909
    3,167
    Okay... If the egr cooler is clogged.
    It will create excessive back pressure, possibly causing damage to the head gasket.
    If it's not cleaned(cooler), and the head gasket fails, it will cause the engine to stop working.
    The engine spins the generators that charge the hybrid battery, if you drive the car on battery only,
    the battery will discharge to the point it will not start the engine.
    Eventually, the car will have not power to move, thus, the wheels won't turn.
    Bottom line, Clean the EGR System sooner rather than later.
  6. ElecTomato
    Maryland
    I'm happy to have learned about this, although surprised to have learned about it in a thread pertaining to changing tires.
  7. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    :ROFLMAO:
  8. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    in another recent tire thread, it turned into someone bringing up buying a 2021 prime and jumping a jeep. Then morphed into license plate issuance and insurance.
  9. Mendel Leisk
    38,260
    It's all connected. :)
  10. Higgins909
    Higgins909 Member
    252
    57
    Good to hear you got new tires. I wonder is the EGR and such still a problem on Gen4s? Will you look at that! Mendel has a new photo! I still don't have one. :D
