Replace 2005 12 Volt Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kirk05Prius, Jul 5, 2021.
  1. Kirk05Prius
    Kirk05Prius Junior Member
    Peoria Illinois
    Bought used 2005 prius nov 2016. Almost 5 years I've owned, pretty sure my 12 volt battery is going dead.
    I replaced my headlights 3 months ago. They are both sporadically going off now. Flipping them off & on brings back for a very short time. & they aren't real bright.
    I spent $1,600 getting brakes done at mechanic shop. Now all my brake lights are lit up. Vsc, brake, traction control, etc.
    & my mileage is like 35 mpg vs normal 40.
    Three options I'm seeing
    1. Agm battery large capacity project someone posted. More work than I want to take on.
    2 self install Amazon ACDelco Gold B24R 24 Month Warranty Hybrid Vehicle AGM BCI Group...
    • $247.81$247.81
    3. Will price at Toyota dealerships hopefully open after the 4th of July. I'm about 4 hrs from home in Indianapolis.
    If i hadn't seen my dad's 2007 hybrid camry go electronically crazy when his 12 volt went out, I'd probably be alot more freaked out right now
    Anyone with recent price points/experience/advice for replacing gen 2 12 volt?
    52,286
    i paid $210. plus tax at the local dealer. i doubt the headlights are a symptom of a bad 12v though. maybe a loss of a few mpg's as the hybrid battery tries to keep it charged, and the engine runs more to charge the hybrid battery.
  3. Kirk05Prius
    Peoria Illinois
    Just got back from Bill Estes Toyota.
    They Tested the battery. The battery was good. Thanks to Bill Estes.
    30 year technician told me to replace the hiid headlights with regular headlights. Computers & ballasts probably have water in them.
    Battery was gonna be $250 installed + tax. 84 month battery. Dealership seems like best deal for battery. Pep boys wanted $115 to install.
    Anyone point me to a thread to replace the hiid headlights with "normal" headlights. Thanks.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,774
    831
    Southern California
    Not too long ago I bought one at the dealership and installed it myself. It wasn't difficult. The worst bit was loosening the nut at the negative post, as it faces "the wrong way" towards the back of the car, which makes it hard to reach. A tiny ratchet (about 4" long) worked but a normal size 1/4" ratchet (more than twice that size) was unusable in the same location.
    Just be sure that you don't let the hatch close while the 12V is out of the car or disconnected or you will have to crawl into the back to use the manual hatch release. That is awkward and uncomfortable.
    As you noted, MPG decrease is a symptom of a very weak 12V battery.
  5. Mendel Leisk
    41,825
    Oh dear... Prius brake maintenance has a few gotchas.
    If just doing brake pads clean up and relube, you want to disconnect the 12 volt negative cable, and/or make REAL sure the driver's door is not opened.
    If you're going to drain brake fluid, then you either want to have Techstream, OR put the car in "invalid mode".
    More info on those if you're interested. Simplest route: take it to a dealership, tell them the full story.
  6. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    Very best battery that will outperform all the others and only costs $100 is this one: https://ebay.us/vN4JsP
    If you decide to buy this one let me know and I'll post pics of the bolts and washers you need to buy at hardware store so terminals mount properly...
    Kirk05Prius likes this.
  7. bisco
    52,286
    shouldn't the mech fix the brake lite problem for no?
  8. bisco
    52,286
    there are lots of hid threads
  9. bisco
    52,286
  10. Kirk05Prius
    Peoria Illinois
    Prius hybrids sales and service Scottsburg Indiana
    Prius specialty store about 90 minute south from Indianapolis.
    They changed the hiid lights over to halogen.
    I had a ghost code saying my catalytic converter was blocked. They replaced with aftermarket catalytic converter & gave me some $$s. My mpg was up to 41.5 with AC kicking in 91 degree weather. I was getting 38 or 39 mpg before.
    They got brake codes to go away.
    Overall very happy. But true test is driving it in the dark tonight.
    Definitely will be taking prius for further work to autobeyours.
  11. bisco
    52,286
    you found a good one
  12. Kirk05Prius
    Peoria Illinois
    Car drove great. Headlights very bright.
    All the way up to 43 mpg at one point.
    No warning lights on.
    COUPLE THINGS I LEARNED
    1. HID LIGHTS BAD DESIGN (my car has 205k miles)
    2. Smart key equipped Prius take a bigger 12 volt battery. I turned smart key off after reading how it can drain some 12 volt batteries.
    Hopefully i can get some trouble free miles. Although my tires are about in need of replacing.
  13. Sebpercu
    Sebpercu Junior Member
    San antonio
    Hi PriusCamper, can you give more information about the 100$ ebay's battery and installation ? I need to change my 12V battery.
    thank you
  14. PriusCamper
    12,985
    5,281
    Here's the link to the 12v: https://ebay.us/vN4JsP
    As for installation, the battery is slightly taller, so I rebend the hold down bar across the top of it, but you could also do this by adding a longer bolt to where it mounts in front of the battery, or by modifying or removing the metal tray the battery sits on top of.
    The existing terminals work fine on this battery as long as you buy the longer bolts below and sandwich the terminal between two washers that are slightly larger than each terminal:
  15. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    I always get original Yuasa or Toyota battery. They last much longer 7-9 years in the past. I heard yellow top Optima works too but not as good as Yuasa in long terms. For 3-6 years it may work fine and cheaper.
    This is the reading of my 12V battery in 3rd Gen Prius 2015 original. Without load 11.9, under load/headlight 11.3, full load heater, blower defroster 10.8 V, outside temperature 5C.
    I have smart keys, never have any problems since 6 years ago with original battery. I won't spend money on something still good.
    I don't believe chinese 12V battery that claims high capacity, etc. We don't trust them and they don't last as long as typical generic 12V battery. We still need AGM because it is on the trunk and next to passanger and HV battery
  16. bisco
    52,286
    you should probably carry a jump pack if travelling beyond your 'car won't start' comfort zone
  17. Ellis Fereday
    Ellis Fereday Junior Member
    26
    In need of a non smart key battery asap...been back ordered with not ETA from toyota for weeks. How can I be sure this will not be too powerful for my non smart key model as I ruined my HV battery with a wrong battery from Oreilly auto parts before. I would like to know what hardware I need to buy as well. Thank you
  18. bisco
    52,286
    you can't have a 'too powerful' 12v battery, as only the voltage matters.
    can you tell us more about your o'reilly experience? something seems off
    dolj and PriusCamper like this.
  19. Ellis Fereday
    26
    apparently there is a difference between the smart key and non smart key battery requirement. From what I understand the non smart key require less cranking amps/amp hours. I went through 3 of the smart key batteries and fried my HV battery. Been using a charger every day for 3 months and I am over that process. Just trying to find a correct battery now that the OEM battery is on back order with no ETA available. OEM is a 20 HR 35 Ah with 272 CCA but nowhere to be found. Thank you
  20. Ellis Fereday
    26
    I did find this one locally. it has much higher cranking amps than the 272 of my OEM battery as well as higher Ah's too. Just don't want to repeat my last debacle and damage my HV battery with too much extra power because of my non smart key model.
