Brake, ABS, VSC warning lights all on
Discussion in 'Prius v Main Forum' started by harold, Jul 3, 2021.
  1. gromittoo
    gromittoo Active Member
    718
    285
    philadelphia
    2013 Prius v wagon
    I am just impressed that he found a Toyota Dealership service department open on July 4th Observed.
    Samuel Williams Jr, Merkey and harold like this.
  2. Merkey
    Merkey Active Member
    252
    228
    Birmingham, Michigan
    Great summary. Thanks.
    harold likes this.
  3. Merkey
    252
    228
    My Scan Gauge says no codes found. Does it have to be an official Toyota scanner to show codes?
  4. rjparker
    7,570
    4,438
    Good news indeed but, frankly, expected. Not quite hitting the lottery when thousands of others have received the same consideration (including me years ago). I think the 800 lb gorilla is the head gasket issue, also experienced by many for years but now approaching critical mass. Excuses abound but its clearly a design flaw that manifests in a slow, intermittent fashion. I hear the Iranians are developing a secret egr stockpile based on Mendel's recommendations. Hopefully Microsoft has hidden code in the valve.
    Tim Jones and Merkey like this.
  5. ChapmanF
    15,078
    It might be possible to program a ScanGauge to retrieve brake system codes.
    Conveniently, the brake system in Gen 3 still has the ability to blink out two-digit codes on the dash lights. Getting the codes that way eliminates any dependency on a scan tool, and eliminates all those "are these really the codes, or is it my scan tool?" questions.
    Mollyisadog, Merkey and harold like this.
  6. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    Just picked up the car. Asked what cost would have been. $3,239.16 which would include 3 days rental car loaner. I’m happy!
    #26 harold, Jul 8, 2021
    Merkey, privilege and Air_Boss like this.
  7. Air_Boss
    Air_Boss Senior Member
    3,910
    1,065
    New Yawk
    Big win, even if not MegaMillions level.
    harold likes this.
  8. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    I’m happy!
    privilege likes this.
  9. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    Are there any other consumer support programs for our Prius V’s like the one for the break booster/abs?
    Mollyisadog likes this.
  10. Tim Jones
    Tim Jones Senior Member
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Toyota told me $2100 when they fixed mine...............
  11. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    gromittoo likes this.
  12. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    Make sure you have the firmware update for the inverter and that will be done with the new brakes..... because the Power module inside it will blow next.....and leave you stranded....
  13. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    Are you referring to the firmware update that was done under the recall?
  14. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    When ever u go to toyota they are supposed to make sure your up to date.....
  15. harold
    harold Member
    213
    34
    SoFla
    2013 Prius v wagon
    Heard the booster pump come on a couple of times while stopped,not like before where it was always constant but I’m now keenly aware when I near it. how often is it supposed to come on?
    have a great weekend
  16. Air_Boss
    3,910
    1,065
    New Yawk
    I only hear ours on pre-startup.
  17. Tim Jones
    1,679
    547
    SE Texas
    2011 Nissan LEAF
    another toyota blunder..... yes they fix it.....but really bad if your on a trip. Very inconvenient.
    I know firsthand.....inverter, brake system and head gasket......did put a new traction battery in but was expecting that. And of course the entire EGR System was Plugged.
    Kind of a screwy car but they do get good mpg.
    #37 Tim Jones, Jul 16, 2021
