Navigation
Discussion in 'Gen 3 Prius Audio and Electronics' started by Jith, Feb 20, 2017.
  1. Jith
    Jith New Member
    Colombo
    I'm new to this and I'm from sri lanka.I have 3rd generation Prius GS(2014) and it has an audio player which has NHZD-w62g model number. It has japan navigation map and how can i install sri lanka navigation map on it. Plz tell anyone know.
  2. lumpy95
    lumpy95 Member
    417
    72
    Mojave Desert, Cal.
    Go to a local dealer and they should be able to update through the USB port.
  3. KiwiTim
    KiwiTim New Member
    New Zealand
    2015 Prius Plug-in
    Hi Jith,
    I have the NHZD-W62G also. Did you manage to change the language settings from Japanese to your language. I want to change mine to English and also install maps for New Zealand. Apparently it is normally done with an SD card from Toyota, but Toyota New Zealand could not help me. Did you find a solution?
