Rear Ride Hight.
Discussion in 'Gen 2 Prius Technical Discussion' started by Seninha, Jun 16, 2021.
  1. Seninha
    Seninha Junior Member
    IJmuiden, Holland, Europe
    I purchase my Prius a year ago, and it came with 15" wheels. I had always the idea that the back was to low.
    This week I purchase some 17 inch wheels and when changing them I looked at my coils and dampers and it all looks good.
    Wonder if this is correct, or can it be that the back is lowered??
    Left and right side are the same
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Looks a little low maybe but not bad. Get under the back of the car on the ground and take a lot of pictures of the suspension pay special attention to the struts.
    I haven’t a clue where Ijmuiden is so don’t know what the climate is.
    many many reports of bad rust and the rear end Strut/spring broken from corrosion.
  3. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    It is in The Netherlands and is a cool coastal climate.
    The OP could also check the rear springs to check that are not cracked or damaged in any way.
  4. Mendel Leisk
    38,709
    Yeah anywhere in the world, please include some country info. Avoid esoteric abbreviations too.
    edthefox5 likes this.
  5. edthefox5
    10,096
    4,805
    Clearwater, Florida
    If only someone had mentioned that.
  6. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    Here are leaf helper springs for $20 for a set of 2. The rear springs generally are very weak springs on the 2nd Prius. I put these rubber spacers and was able to keep the rear sag to a minimum and these spacers don't effect the driving characteristics of the cars handling.
    I decided to drill holes and zip tie the rubber spacers so it wouldn't fall out. I can see these spacers falling out if the rear end articulate over bumps.
    Rear both shows before and after shot car with 200 lbs stuff in the trunk. 20191230_144754.jpg 20191230_143518.jpg 20191230_142744.jpg IMG_20200108_225814.jpg
    Android ?
  7. Seninha
    Looks great. Will have a look if i can get them here in HOLLAND ..thanks for your pictures
    Last time i checked springs were fine so rust or something broken is not the issue
  8. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
  9. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Don't underestimate the utility of zipties and duct tape! Lol
  10. Kaptainkid1
    308
    243
    Los Angeles
    Yup! It's been on for 3 years no problem. I just drove a 1000 mile Overlanding trip with 900 lbs gear and people in the Prius. I tow stuff with the Prius and the rear hitch height is very important when towing and tongue weight should be accounted under heavy load and braking. 20210714_184450.jpg 20210623_121135.jpg IMG_20200108_225814.jpg 20200209_115805.jpg
    Android ?
