  1. Otium
    Otium New Member
    22
    Virginia
    Installed the oil catch can and a new PCV valve while I was down there.
    icyrius and Burna J like this.
  2. Jungenas
    Jungenas Junior Member
    Ireland
    Since i bought the car last month, so did some maintenance, yesterday cleaned egr cooler (was almost completely clogged, water was barely going through), cleaned egr valve, egr pipe, intake manifold, installed new pcv valve, oil catch can, changed gearbox oil and installed back HV battery after DIY reconditioning, didnt change any cells, just discharged and charged 3-5times depending on the results. Dr.prius app showed life expectancy 42% before, after 74% (dont know if its accurate). Today did some soundproofing, just 2 front doors, but it makes a difference, planning to do back of the car since i got some materials left. I think thats it. Didnt do much photos though. and i like fixing the cars :)
    Dr.pri, icyrius, xliderider and 2 others like this.
  3. Mikethe3d
    Mikethe3d Junior Member
    Vancouver, BC
    Custom shift knob and window tint job this week. (Shift knob is a very good size, comfortable to rest hand atop while driving)
    PXL_20210725_184021881.jpeg PXL_20210725_184050054.jpeg PXL_20210725_184059580.jpeg PXL_20210725_184436034.jpeg PXL_20210725_184558985.jpeg PXL_20210725_184657576.jpeg
    #18823 Mikethe3d, Jul 26, 2021
    Dr.pri and Burna J like this.
  4. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Dr.pri, Steph1972 and Mikethe3d like this.
  5. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    installed a new roof rack!
    Dr.pri, Steph1972, w84me and 2 others like this.
  6. Jungenas
    Ireland
    Changed steering wheel leather.
  7. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Where did you buy that?
  8. Jungenas
    Ireland
    From a Chinese site aliexpress, but i live in Europe, don't know if they ship to US, but i saw them on amazon as well
  9. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Great picture !!!!
  10. Dr.pri
    Dr.pri New Member
    South Florida
    Replaced the doors actuators and installed new radio. 7F50E733-4B55-4D6A-80F6-9CF46B6A551E.jpeg
    ockevin, w84me, Burna J and 2 others like this.
  11. Dr.pri
    Dr.pri New Member
    South Florida
    Any wind noise?
  12. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    thank you!
  13. AzusaPrius
    AzusaPrius Senior Member
    2,221
    929
  14. M One
    M One Member
    63
    108
    Kuala Lumpur, Malaysia
    Got error code C1645, abs lights on.
    Went to shop and found out rodent had taken a bite off ABS sensor cable :(
    Mechanic was kind enough to solder and reconnect all wires. Let's hope it works and cost is low. 1034425387.jpeg 1630664782.jpeg 1184120020.jpeg
    Burna J, Steph1972 and Jungenas like this.
  15. ASRDogman
    7,758
    3,967
  16. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    Could you share more details? Radio model, any special brackets or wiring jacks? Thanks
  17. AzusaPrius
    2,221
    929
    Dr.pri likes this.
  18. M One
    M One Member
    63
    108
    All done. Cost USD18 for the labor. Very nice IMO
    Dr.pri and ASRDogman like this.
  19. Dr.pri
    Dr.pri New Member
    South Florida
    It’s from Amazon
    99% of the features that come with the car work like the steering wheel controls. Everything is plug and play, the brackets are used from the stock radio. took me bout 15-20 min to install. The only thing that won’t work is the back up camera (something about the stock camera is 6 volts and the radio being 12v
    ) so I had to run a new one.
    Burna J likes this.
  20. Dr.pri
    Dr.pri New Member
    South Florida
    One more thing, you will need a CarPlay dongle if you want to activate the apple carplay.
