LED Light Bar - Gen 3 with Solar Sunroof Package
Discussion in 'Gen 3 Prius Accessories and Modifications' started by DevinP, Jul 23, 2021.
  1. DevinP
    DevinP Junior Member
    Ohio
    I want to add a light bar to the top of my car, but I'm running into some problems.
    1. I need something with suction cups because the top of my entire car is glass.
    2. I need a way of mounting it such that the front sunroof flap can still flip up.
    3. I need to know what wattage light a Gen 3 Prius could handle. It's not easy looking for this one...
    Yes, I know this is ridiculous, but I've already made the car kind of obnoxious with switching every light to LED. How much worse can I get?
    P.S. I'm not going to use the lights on main roads, like highways and whatnot. I want it to be connected separately from the headlights and be a manual switch in one of the extra slots by the mirror controls.
    This is one that I was looking at, but it won't work because of screws.
  2. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    whats the fastest speed you’ll drive?
  3. SnowMexicanuck
    56
    66
    Quebec, Canada
    From what I've seen "42 LED bar are rated from 9 amp all the way to 20 amp depending on the brand. I had one on my '05 Corolla and it made no visual difference with the electrical system when turning it on (no dash dimming, nothing weird).
    But honestly, I put one on my Corolla since it was a winter beater painted matte green... Something you have to realize is that putting a big flat object on your roof might not help with mpg. From experience with headwind, I could feel it on my Corolla and it was bolted with nutserts in the roof... not sure I'd trust suction cups for that.
    #3 SnowMexicanuck, Jul 23, 2021
  4. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
  5. DevinP
    Ohio
    I'd say up to ~90 MPH.
    True, suction cups might not hold. I know they work for ski boxes at 100 MPH+ but they're pretty aerodynamic.
    That looks amazing! Though, I don't want to lose too much MPG and this will make my sunroof pretty much unusable. If I didn't have the solar sunroof package on my car, I would absolutely do this!!
  6. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    there um... is an option for you and not lose too much mpg, it's just what are you will to do to achieve your goals?
  7. DevinP
    Ohio
    What are you thinking?
  8. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    it's too crazy but I did stumble on these led light bar suction magnetic bases.
    the crazy... roof rack mounted on the side pillar with your light bar or custom mounts for the light bar only, bolted to the upper pillar...
  9. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    What about placing a light bar inside the windshield on top of the dashboard or in front of the mirror? This would satisfy the MPG concerns.
    Just use a rubber gasket to seal the edges against the glass similar to what police use when they have lights mounted in the same place.
    @black_jmyntrn - does the 50" curved lightbar you have fit inside of the car on top of the dash?
    #9 gboss, Sep 2, 2021
  10. tony_2018
    tony_2018 Member
    227
    68
    Have you ever shined a flashlight through glass?
  11. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Most all flashlights have a piece of glass/plastic between the outside and the bulbs - so, yes. Refraction through the thick prius windshield will be a tradeoff when optimizing for mpg, of course, but you could probably reduce some of it to usable levels by removing any additional plastic housing around the bulb enclosure.
    Ideal setup is a popup light bar from within the hood :cool:
