How may I cut the charging rate in half
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bradshawlupton, Aug 1, 2021.
  1. bradshawlupton
    bradshawlupton Junior Member
    buzzards bay, ma, usa
    On a kill-o-watt meter and 110vac I watch the Prius plug-in cycle up to 11 amps in about 5 discrete steps.
    I have a second charging cable and would like to modify it to charge at around 5.5 or 6 amps, obviously for 12 hours rather than 6.
    I have two 220 watt solar panels and a half dozen 120 lb 2 kWh marine batteries.
    I hope to charge my Prius plug-in on sunshine...... I would feel much better with a 1 kw 12v inverter.
    I am comfortable modifying the old charger cable, with a little guidance. Clearly the cable knows how to adjust the wattage gradually up.
    Thank you, Bradshaw in Buzzards Bay MA.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is not the CABLE that knows that.
    Explain again why you want to limit the charging rate ?
    If you connect it to a source that is not capable of supplying the 11 amps, I would hope that the charging controller would be "happy " with less.
    Others with some actual experience can probably provide more information.
    MTN likes this.
  3. LeviSmith
    LeviSmith Member
    111
    NY
    Few things here...
    First off the charger is actually built into the car, that's what's requesting the amps. The cord you're using is an EVSE which is basically a smart extension cord. It basically just connects been the car and power supply and says "is everything ok? Yes? Ok I can supply this much power, here it is.".
    But the default EVSE that comes with the Prius and the charger in the Prius have no amp limit options that I'm aware of. Some cars like Volt have options in the car charger to use less amps.
    Or some EVSE's like mine from openevse have options to only offer the car less amps as well.
    The only other factor you might want to keep in mind is that there is charging overhead just to keep the car computers, etc powered. So when you get down to like only supplying 2 amps you might be losing a quarter of that too overhead and so you end up with a lot of hours of extra energy used.
    MTN likes this.
  4. fuzzy1
    10,583
    Your Owner's Manual gives instructions for limiting the charging current to 8 amps. Here is a snippet from the prior year's OM:
    I have never heard of any other choice for reducing charge current.
    MTN and LeviSmith like this.
  5. bisco
    52,274
    welcome!
    i have never heard of anything like this being done before. you may be the missionary, all the best!(y)
