warning about oil catch cans and California smog test
Discussion in 'Prius v Main Forum' started by Dusty rug, Aug 2, 2021.
  1. Dusty rug
    Dusty rug Member
    47
    32
    Colorado
    2014 Prius v wagon
    just failed a smog test bc of my catch can so to save you guys the 50$ remember to remove your can just for the test and put it back on after words, once you get good at removing your intake you could get it done in under 10-20 minutes.
  2. Mendel Leisk
    41,778
    Sad thing is, they’re saying “can’t have you burning less crud”. :confused:
  3. rjparker
    10,369
    6,491
    Many have reported similar problems in carb states. I am sure if it were factory like in some cars with an auto drain to the crankcase it would be fine.
  4. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    I would just stencil a Toyota part number on the can, and make it look like it is supposed to be there!
    PA where I live is a CARB state, but because we have private inspection stations, I don't think we have this issue.
  5. Dusty rug
    Dusty rug Member
    47
    32
    Colorado
    2014 Prius v wagon
    well to be fair it wasnt that much trouble to take it off for a few hours and reinstall it after the test, its so dumb that a part that will reduce oil burning is seen as an illegal mod for California. makes me wish i never moved here lol
  6. Mendel Leisk
    41,778
    Taking it off is not trivial, but meh. Just think though: the one time you’re back to full-blown PCV dumping into the intake, is during a pollution control check…
    Tim Jones likes this.
  7. Leadfoot J. McCoalroller
    8,123
    7,619
    Pennsylvania
    2018 Prius c
    Pennsylvania annual emissions inspections involve connecting the state-sanctioned computer to the diagnostics port to verify that there is no active maintenance indicator and that all monitors are completed and not left pending. That's it.
    They don't pop the hood to follow hoses or lift the car and compare the catalyst to pictures in a state-published binder like the California smog shops.
  8. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    This
    reminds me of using the Google maps and it always wanting me to take the tolls even though at times its longer to do.
  9. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    Google maps has an "avoid tolls" setting, which I use for personal driving. I sometimes forget to turn the setting off while Ubering. I was over the river in Camden NJ one night, and picked up somebody going to the PHL airport (a 20 minute ride). Google had me driving about 50 miles north to avoid any of the Toll bridges. It added at least 90 extra minutes to the trip, to save a $5 toll. I didn't figure out what had gone wrong until the next day.
    There is an app called "Toll Guru" that does a much better job of dealing with tolls. You tell the app your typical MPG, the cost of gasoline in your area, and how much you would be willing to pay to save one minute. It will offer you routes that actually make sense. This really works in my area, as the PA turnpike is quite expensive per mile, and you can often avoid the toll with only adding a few minutes. The Delaware River is harder to avoid.
    Tim Jones and burrito like this.
  10. Dusty rug
    Dusty rug Member
    47
    32
    Colorado
    2014 Prius v wagon
    man your telling me! i was getting stressed out about driving around with the PVC just pulling oil in, after the test i cleaned out the air intake again and it was full of oil, i only drove 60 miles like that! luckly when i took the catch can off it was bone dry with no oil anywhere inside the intake. i say its trival to remove and reinstall since ive removed the air intake a few times already to cleaning my EGR among other things.
    kinda suck that in the LA area is all mountainous, im getting worse gas mileage here then denver IE 38 avge for LA and 48 avage for denver
    Tim Jones and Mendel Leisk like this.
  11. burrito
    burrito Active Member
    274
    114
    I just got home from getting a smog check in California, on my Lexus. I asked the guy about oil catch cans. He said he'd never heard of them being used on passenger vehicles other than on diesel engines. This particular guy said that if he saw anything unusual he would warn the owner prior to running the test.
    I got the impression he wouldn't care, as long as his computer passed the vehicle.
