Anyone uses Redline oil in gen4 ?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ongbenghui, Feb 6, 2019.
  1. ongbenghui
    ongbenghui Junior Member
    Singapore
    Just checking if anyone has uses Redline 0w20 on their gen4 ? Any diff in performance ?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    [Note that 0w20 isn't the world-wide specification by TOYOTA. Go by the grade your Owner's Manual says.]
    I thought Redline was for use in high-stress situations, eg turbo or an engine which uses oil. PRIUS has a relatively low-stressed Atkinson Cycle engine - I wouldn't be spending extra on a specialty oil for it.
  3. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    correct engine oils are formulated to solve a problem that the engine will undergo.
    it's good to know you care about your car enough to look into these things.
    However, if you want just change your motor oil and transmission oil a bit more frequently then. instead of doing 1 or 2 a year, do 2 or 3 a year. just add one more interval.
  4. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    You are right I thought I should of used 0w20 but in the UK it is 0w16 according to Toyota, it will have to wait until next service now
