2007 battery and jumping issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaryEllen1102, Aug 5, 2021.
  1. MaryEllen1102
    MaryEllen1102 Junior Member
    santa cruz, ca
    Hi there everyone. I know this stuff gets posted all the time, so sorry for the repetitiveness.
    Long story short I have a 2007 Prius that needs to be jumpstarted every time it is driven, but there are no other warning signs that something is wrong. What should I do?
    Read on for lots of details… I have a 2007 Prius that I have owned for 11 of those years. It has 169,000 miles. If you look at previous posts, you’ll see that I’ve had battery issues on and off for several years. The 12 V battery was most recently replaced in late 2019 I believe. Throughout the pandemic it has been driven on and off, after suggestions hear that it needed to be driven more often. For the majority of the time it needed frequent jumpstart it’s from a portable jump starter that I kept on hand. This spring I was able to purchase a new car, and handed down the old Prius gal to my sister who is now living with me. She drives the car daily, however The Prius now needs to be jumpstarted every time it is driven. This can go on for several weeks/months, and we have it needed to call roadside assistance on three occasions to have them use a higher power jump starter to get it going. I have now learned that perhaps these roadside assistance pals are not so smart, as the most recent visit they informed us that the alternator needed to be replaced. I now know that prices do not have alternators. However, I don’t know what else might be causing this ongoing issue. In the car drives well when it is on, gets high gas mileage, all interior lights and dash work fine. There are no warning or other bad signs up on the dash.
    I am at a loss… Is it just another 12 V battery replacement that needs to happen? I will admit that I am not a car guru, so in replacing the 12 V battery twice now I may have made mistakes along the way, so from reading posts and I might need it to check out the tightness level at the different posts. Does everyone have any other suggestions that may help me? We are looking to spend as little money as possible on this stage, due to its age and our financial situation.
  2. PriusCamper
    PriusCamper Senior Member
    12,706
    5,135
    Pacific Northwest, USA
    Getting a high quality smart charger on the 12v overnight might revive the battery, but most likely you bought a bad battery in 2019... I actually know of 2 other Prius I've worked on that had this same problem. So many garbage battery sellers out there, especially Optima.
    Anyways, here's best price for replacement 12v... If you decide to go with this one let me know and I'll post info about bolts and washers you need to connect the terminals. https://ebay.us/vN4JsP
  3. MaryEllen1102
    santa cruz, ca
    Is this another name for a trickle charger? i bought one yesterday, arriving tomorrow, and hoping it helps the issue.
    Last night we tightened the loose-ish positive terminal on the 12v, and then jumped it VERY carefully from the back battery to a good working car. After 6 minutes connected, the prius turned on and the diagnostic screen when flicked to it showed 13.8v.
    This morning, dead battery as we predicted. portable jump starter didn't work. jump started from back battery again.
    repeated this all day (have to work, no option otherwise to get to and from).
    Anything i need to know about a trickle charger in order to get it to work on the prius?
    i'm hoping to jump it one last time tonight and take it to autozone to get them to do a "load test" on the battery? i'm assuming i just ask them for that?
  4. ChapmanF
    18,089
    The 13.8 volts you saw after making the car READY only confirms that it was READY; that is higher than the battery voltage, and is generated by the car while it is READY in order to charge the battery.
    If the battery is fully discharged, it takes quite a while to fully charge it. If you are in a place where you could leave the car READY, without someone breaking into it and driving it off, and without its exhaust entering your home, leaving it in READY for around 16 hours ought to get it within hailing distance of full charge.
    If you didn't leave the car READY that long, but only shut it off again shortly after seeing the 13.8 volt reading, then the battery didn't get anywhere near recharged, and dead again next morning wasn't surprising.
    If the charger you bought is capable of delivering 3 or 4 amps (that might be considered more than a 'trickle' charger), that would take about the same amount of time to reach good charge. If the 'trickle' is smaller than that, the time will be proportionately longer, perhaps even impractically long. But a trickle or maintenance charger can be a good way to keep a battery charged, if it's decently close to charged to begin with.
  5. PriusCamper
    12,706
    5,135
    Trickle chargers don't charge a drained battery very well, almost has never worked for me. They're designed to maintain a charge not make one. Whereas a smart charge will go up into 8 amp range, some even higher and control the amps going into the 12v based on feedback from the 12v and then once its fully charged it goes into trickle charge mode.
  6. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    If you bought the battery less than three years ago, it may still be eligible for a free warranty replacement as many are these days. If not then it’s usually eligible for a prorated discount on a new one. The date code is on the battery and if it’s a name brand or a house brand, take it back to where you bought it and see.
  7. MaryEllen1102
    santa cruz, ca
    Thanks all! I don’t want to be one of those post and disappear folks.
    We bought a 3amp charger from oreillys. Took about 24 hours to fully charge. After that it’s been working well for 2 days. No need for any jumps so far.
    Tomorrow we’ll have a chance to test the charge and make a plan to take the battery in if needed.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    NO, not the same.
    You need a small, automatic, "smart" battery charger.
    That is NOT the same as a dumb trickle charger.
  9. sam spade 2
    7,035
    2,801
    2017 Prius c
    By using it for a few days, you have effectively tested it ......somewhat.
    BUT if you replace it or not, you NEED to connect your charger to it overnight any time it won't be driven for a week or more.......to KEEP the battery from dying a premature death.
    kc&her07 likes this.
  10. kc&her07
    kc&her07 Junior Member
    DFW
    Mary Ellen, I have a battery I've been using a handheld charger on for almost a year. Wondering about your battery's status. I'm in a similar situation after sitting idle for too long early 2020, I've been using a handheld charger to jumpstart every single time. Was just pricing a new battery and wondering if I should first try a smart charger on it.
