Inverter radiator replacement instructions request
Discussion in 'Gen 3 Prius Technical Discussion' started by FastForwardRay, Oct 13, 2020.
  1. FastForwardRay
    FastForwardRay New Member
    San Francisco
    Four Touring
    Hi folks,
    I have been a long time lurker benefitting from your discussions, so let me start with a thanks for that :)
    A stone has damaged the radiator inverter of our beloved Prius. I was told repair is not possible.
    Money is tight so I'd like to diy the replacement. I can't find instructions online though.
    Has anyone here done this before? What's the complexity? I'm not particularly good at cars but I am willing to learn and do this.
    Thanks.
  2. Justin Henderson
    Justin Henderson Junior Member
    39
    Salt Lake City
    2014 Prius v wagon
    Did you ever find instructions? I believe I have the same issue. Our prius V had error codes indicating inverter cooling failure. I noticed that the inverter reservoir was empty. I topped it off, noticed it all leaked out on the driveway. I thought initially that it was the inverter pump failure but on further inspection I believe it is OK and the culprit is a damaged radiator. It has coolant leaking out from somewhere in one of the aluminum fins.
  3. tony_2018
    tony_2018 Member
    204
    58
    - Requires you to remove your front bumper
    - the inverter radiator sits above the condensor so you'll need to be careful
  4. tony_2018
    tony_2018 Member
    204
    58
